Insignia Led Lines in Screen
  • Gadjet
    • Aug 2012
    • 248
    I have a Insignia led tv showing the following picture. Is this a board or panel issue?
  • Gadjet
    • Aug 2012
    • 248
    Re: Insignia Led Lines in Screen
    Model number is NS-40E560A11
      Likely panel, but may be repairable, if it is a tab bonding issue for example.
      • Stanley1843
        by Stanley1843
        06-29-2024, 11:54 AM
      • Ancient1
        Strange LG TV issue : Image vertical lines in black screen
        by Ancient1
        Hi
        Asking for a friend.
        I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
        but here its the opposite !
        TV has new T-con = same issue
        A missing panel voltage would have global effect
        So , what should one do ? how can I find where the fault is ?
        Thanks !...
        02-05-2025, 03:37 PM
      • wizard13
        Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
        by wizard13
        I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
        I have checked the forum and the available documentation but could not find a solution specific to my issue.
        • Brand & Model: Dynabook Satellite Pro C50D-B-100
        • Part Number (P/N): PYU13E-00C00PFR
        • Serial Number (S/N): 22028896H
        • System Configuration (SC): A1PYU13E1127
        • Motherboard Model: IP3_ACN16_MB_V21_20211222A
        • Power Input: DC 19V –
        02-28-2025, 02:43 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
