manuel.
  • manuel432
    • Sep 2012
    • 11
    • la
    manuel.
    its a sony dlp kds-60a3000 from 2007'
    here is the problema turn tv on green light blinks 5 times tv turns on stay on for minute and a half scree go black. green light blinks 35 times tv cones on againg for a minute plus and the cycle repeats on and on.
    healp
    Re: manuel.
    Closest I have is for the A2000 series, may be close enough or completely off.
    • manuel432
      • Sep 2012
      • 11
      • la
      Re: manuel.
      Hi tom66 ihave no idea if the are close or not,i look into it
      thanks manuel 432
      • R_J
        • Jun 2012
        • 9633
        Re: manuel.
        This is from the manual:
        5 blinks = lamp Driver, Check power supply (ballast) 400v cn6501 on G board
        Ckeck ic4001 on FB1A board
        If the screen lights, then blacks out, it could be a weak lamp, as for 35 blinks there is no code for that.
        • Bassman
          • Dec 2011
          • 5
          Re: manuel.
          How old is the lamp? I find that the average lamp lifespan is 2-3 years. If you pull the lamp, you can a lot of times tell visually if it is bad.
          • manuel432
            • Sep 2012
            • 11
            • la
            Re: manuel.
            to bassman I think the lamp is more than a year old, I remoobed the lamp and notice that the from glass was loos I order a new lamp I whont get it in 3 or 4 days.
            I will keep you up to day.
            manuel432
            • manuel432
              • Sep 2012
              • 11
              • la
              Re: manuel.
              RJ. try to send you some fotos two trys and they fail, I removed the fron cover to see the cb, clean the fans, they seam to be working ok, need to work sending the pictures.
              • manuel432
                • Sep 2012
                • 11
                • la
                Re: manuel.
                RJ>>> I think I got the picture problem down, hear the photos of the boards,the 1st one I think is the lamp driver all the components look ok the second is the main power board.
                another error cant upload the photos,can only send 4.7 at a time I cut down the photos 2.3 mb, got to keep trying.
                keep you posted manuel432
                • Biruslapio
                  Panasonic P58V11B 8 and 12 blinks error "fix"
                  by Biruslapio
                  Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                  Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                  04-13-2021, 07:13 AM
                • hoarderteks_kyriakos
                  Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
                  by hoarderteks_kyriakos
                  Hello.
                  Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
                  Here is what happened:
                  At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
                  10-08-2025, 07:33 AM
                • Nairolf
                  Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                  by Nairolf
                  I have a Samsung DM32D display.
                  When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                  Here’s what I have tried so far:
                  1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                  2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                  3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                  From these tests, I suspect the problem might be on the mainboard. Could anyone...
                  08-24-2025, 03:47 AM
                • Andre Gilbert
                  by Andre Gilbert
                  11-20-2024, 08:52 PM
                • Taurus12
                  Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                  by Taurus12
                  Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                  I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                  i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                  Any recommendation on what I have to do next? Thanks in advance
                  06-10-2025, 05:05 PM
