PRIMA LCD 32" TV clicking on off
  • pyrosster
    • Aug 2013
    • 43
    • Spain
    I picked up this tv today.
    The power supply board have this reference L32W19-20.
    When I push the power button the screen turn on and off very fast because it clicks on and off quickly. (the backlight turn on and off very fast repeately).
    There was a visible blown capacitor which I changed.
    Near of this capacitor, there is a 3W resistor which have symptoms of overheating and the colors are not distinguishable. This resistor measure 450ohms but I think it should be 1K.
    I measured the output of the connectors and it output +5VDC in standby but when I turn on I don't see any other voltage than +5VDC.
    Any advice what to check on the power supply board?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: PRIMA LCD 32" TV clicking on off
    Check F0502, it is just barely visible in your second picture.
    Also, replace the rest of the capacitors. The 'TL' and 'JH' ones are crap! Is that Daewoo capacitor the new one? And is it low-esr? I sugguest using somthing better like panasonic or nichicon capacitors.
    Muh-soggy-knee
      With any rapid backlight flickering problems, I always check the voltage across the large 450V capacitor.
      • pyrosster
        • Aug 2013
        • 43
        • Spain
        I have checked continuity on FU502 and FU503 (first picture) and both are ok.
        Yes, the Daewoo capacitor is the new one. (Daewoo RMU Series 105º Standard).
        I bought these capacitors at the local electronics store. Let me know if these are ok.
        How can I safely check the voltage across the high voltage capacitor?
        The 3W resistor should be changed?
        Thanks.
          The Daewoo is probably not suitable, the RMU series is not low impedance and will likely fail
          Testing the voltage across the 450V cap is done with two probes and two steady hands. If you slip, you will get a loud bang and blow the mains fuse or trip the main circuit breaker, but other stuff will probably survive... Just be careful.
          • pyrosster
            • Aug 2013
            • 43
            • Spain
            I have tested the voltage across the 450V capacitor and is ok too. The power supply continue to click on and off and the backlight turn on and off.
            I see a IC with the reference CP1002PN (with Power Integrations Logo). How could I check this IC?
            Thanks again.
              When you say the voltage across the 450V capacitor is "OK" what do you mean?
              • pyrosster
                • Aug 2013
                • 43
                • Spain
                I checked again across the big capacitor and show 375 volts, this is normal? I used DVM at the 600VDC scale.
                The capacitor dont show bulging at the top.
                • pyrosster
                  • Aug 2013
                  • 43
                  • Spain
                  I checked output voltages and I see 22VDC, 13VDC and 1.5VDC. The 1.5V is normal?
                    375V is OK, but is it stable as the screen flickers?
                    Where, which pin, are you measuring the 1.5V DC?
                    • pyrosster
                      • Aug 2013
                      • 43
                      • Spain
                      Today I measured big capacitor voltages again and it show between 355V - 358V DC.
                      I post some pictures where I'm measuring these voltages.
                      what can I do?
                      Thanks.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Fixed link: (The link is a 404, because it's malformed.)
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                          355 to 358V is too low. Can you check what your local AC mains voltage is?
                          • pyrosster
                            • Aug 2013
                            • 43
                            • Spain
                            local AC mains voltage is 235V AC.
                              Check the voltage across this capacitor.
                              • pyrosster
                                • Aug 2013
                                • 43
                                • Spain
                                the voltage across the capacitor is 13V DC
                                  Does it fluctuate, or is it steady?
                                  • pyrosster
                                    • Aug 2013
                                    • 43
                                    • Spain
                                    I'm measuring voltage again and dont give any reading. only 0.02 volts and fluctuate.
                                      I'm confused, are you saying it's fluctuating by 0.02V, or is only 0.02V now? Is clicking on and off still happening or not?
                                      • pyrosster
                                        • Aug 2013
                                        • 43
                                        • Spain
                                        yes. yesterday I measured 13V DC and fluctuating +-0.3V DC. Today I'm measuring the same capacitor and dont give any reading, only 0.02V DC.
                                        The clicking on and off is still happening.
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
                                        • chth96
                                          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                          by chth96
                                          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                          Since then, This AC/DC adaptor have been out of order.
                                          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                          And Is there any possibility that it will suddenly explode as well as to be out...
                                          12-03-2023, 04:40 AM
                                        • badcap111
                                          Xiaomi mi 9T missing resistor
                                          by badcap111
                                          Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
                                          I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
                                          Is...
                                          08-07-2023, 10:42 AM
