Lg 42lg5010
  • zerocool
    • Jul 2013
    • 13
    • gwent
    Lg 42lg5010
    This is my second posting, with another fault that I would be grateful of any assistance in solving.
    I recently picked up an LG 42 inch LCD tv, the backlight is okay, I have checked all voltage outputs from the power supply board, and these all check out okay. There are no bulged capacitors, so the power board appears to be okay.
    The problem with this is that the picture on the TV is very poor, there are multiple lines on the screen and the colours are all over the place.
    I am hoping that this is not the dreaded ribbon bonding to the screen and that someone out there with a vastly superior knowledge than mine will be able to point me in the right direction.
    At best I'm hoping that this will just be a board problem and as such a relatively easy/cheaper fix than binning the set.
    I have attached some picture of the screen, and also of the rear of the TV.
    Any help with this will be gratefully received
  • zerocool
    • Jul 2013
    • 13
    • gwent
    Re: Lg 42lg5010
    Hi again, I was wondering if anyone has had this problem before, I am told it could be a tab bonding failure but I am unsure if it's this as there are no visible lines down the screen, or if it was the TCON board at fault. I know that TCON boards give varying issues with regards to the display, but I was hoping someone out there could point me in the right direction.
    Thanks.
      Re: Lg 42lg5010
      I would say tab bonds / panel fault.
      • zerocool
        • Jul 2013
        • 13
        • gwent
        Re: Lg 42lg5010
        Thanks tom66 for the reply. I have checked the tab bonds, and also both ribbons to the TCON board and I cannot seem to alter the picture in anyway- good or bad.
        As an update to my last post, while watching the TV, the sound is okay but for a high pitched almost squealing click for a split second every now and then. Part of me thinks this might be a capacitor discharging but I've visually inspected all the capacitors on the power supply board and these all look to be okay. Is it possible that I may have a faulty main board or TCON board with bad capacitors?
        Has anyone had to replace capacitors on any other board apart from the power supply board.
        • zerocool
          • Jul 2013
          • 13
          • gwent
          Re: Lg 42lg5010
          Hi all, Have not had the time to continue fault finding with this TV, but I will persevere and I will post and let you all know the outcome, good or bad.
            Re: Lg 42lg5010
            It sounds like you are have failing x/y drive ICs which are on the flexible PCB. The squeal may be coming from the round inductor on theT-CON board due to too much current being drawn by the ICs.
            https://www.badcaps.net/forum/showth...ight=LG+47LH55
            post 10:
            • zerocool
              • Jul 2013
              • 13
              • gwent
              Re: Lg 42lg5010
              Hi all, Thought I would post and give everyone the good news. The fault with this TV turned out to be the TCON board. Took the plunge and purchased a second hand one from ebay, fitted and now all is good.
              Thought that this might be handy for anyone that may be having or may have in the future, a similar fault.
              But once again thanks to all on this forum who have taken the time to help me out.
                Re: Lg 42lg5010
                Well, I didn't expect that, nice fix.
                • CDNBrewer
                  Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                  by CDNBrewer
                  Hello Everyone,
                  I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                  Symptoms:
                  • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                  • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                  • I swapped the Left and Right surround
                  08-05-2025, 09:29 PM
                • zomi
                  Manual cof bonding success rate ?/ feedback wanted
                  by zomi
                  Just wanted to get some feedback,
                  whats peoples' success rate with cof bonding repairs.....
                  09-23-2024, 12:45 PM
                • Duranitron
                  HUAWEI MATEBOOK D14 (DAH98NMB8B0 REV: B HF) need schematics and board view
                  by Duranitron
                  Got hold of this HUAWEI MATEBOOK D14 (DAH98NMB8B0 REV: B HF) intel i5 with 8gb ram. My friend told me that she is using the unit for 2 hours, then sudden black screen, she plug the adapter hoping it's just battery issue, charge the unit for a while. nothing even charging light. charging adapter is ok.
                  SYMPTOMS: No power, no charging lite, no sign of life
                  WHAT I DID: open the unit, visual inspection, check for burnt components, looks clean, no burn or corroded components, When charging the unit i got 19volts at the charging pin. i notice a over heating component...
                  09-11-2024, 10:31 PM
                • Hornnumb2
                  ACF bonding?
                  by Hornnumb2
                  Has anybody gave this ago with new acf tape and the t handle soldering iron? It just kills me to throw a 75in tv away.
                  12-22-2020, 07:13 PM
                • Geomih
                  CPU socket replacement soldering profile
                  by Geomih
                  Hi All - I am hoping someone can help with some pointers (complete noob here!)
                  I have recently purchased a Scotle HR460 BGA reball machine (it's a bit old and I think the company no longer exists either), but as far as I can tell it is a competent and unmolested machine that should be good enough for my needs.
                  My biggest problem is that it came with no profiles, and I must re-create all of them from scratch, something that is very scary for someone that doesn't really know what they are doing.
                  The simple stuff like a small memory module isn't a big deal because there are
                  12-11-2023, 11:07 AM
