LG 42" Plasma 42PJ560R - no picture
  • abhi1981
    • Aug 2013
    • 35
    • India
    I'm from India. I have a LG 42" Plasma tv which is three years old. About a month back , it would start with a black screen. There was sound but no picture. It would behave normally-- no blinking LED, except that there was no picture. It would respond to the remote and I had to turn it off and on from the remote once to get the picture back. This on/off time increased to about half an hour. Once it turned on it would work perfectly until I turned it off from the remote. Now, even after long on/off attempts, there is no picture-- TV still works normally except no picture . The relay clicks normally every time with each on/off cycle. The mains supply is 220V. TV rated power is 100-240V. Sometime back the mains voltage was 270V. Could that be a problem?
    I have opened the back cover --- no bulged capacitors or blown fuses.
    Please help.
    Re: LG 42" Plasma 42PJ560R - no picture
    This is likely to be a main board fault.
    If you take some pictures of the internal circuit boards in this TV, there is a way for you to run a self test to confirm if the main board is at fault.
    • abhi1981
      • Aug 2013
      • 35
      • India
        Need a close up of this board. You will need a small piece of bare wire to use as a test jumper.
        • abhi1981
          • Aug 2013
          • 35
          • India
          Is this ok??
            Perfect.
            Power to the TV must be OFF (power cord disconnected.)
            Unplug the connector highlighted in red. You will probably have to press the two sides to release it.
            Then place a wire jumper across the two holes highlighted in blue.
            Plug the TV in again and turn it on. Test patterns should appear, like below:
            http://www.youtube.com/watch?v=xgrvR...9BzGSA&index=1
            If you see these patterns, then the main board is at fault. (The board you are testing is the control board. The red cable connects to the main board.)
            • abhi1981
              • Aug 2013
              • 35
              • India
              No. There are no patterns, just a black screen. The relay clicks when I switch on the mains and press the power button on the remote.
                OK, do you have a digital multimeter?
                • abhi1981
                  • Aug 2013
                  • 35
                  • India
                  Yes, I have this one.
                    OK, that's perfect. Set it one click left of the "off" position (600V DC).
                    There's this board in the middle of the TV, this is the power supply:
                    https://www.badcaps.net/forum/attach...9&d=1375551633
                    There's a connector on the left, which has points marked VS and VA among others.
                    You want to put the black probe of your meter, which goes in COM, on part of the metal frame of the TV. The holes for the wall mount bracket are a good place for example.
                    Then touch your red probe (in Volts/Ohm/mA) to the VS, and then the VA points. Note the reading on each (you only need to measure one VS and one VA.) The sticker at the top left of the plasma panel states what they should measure, it appears to say Vs: 205V and Va: 60V.
                    • abhi1981
                      • Aug 2013
                      • 35
                      • India
                      Vs=203v
                      va=59v
                        The power supply is working, then. The voltages are fine.
                        In a dark room, can you see a slight glow emitted by the screen?
                        Can you show me how you configured the test pattern jumper?
                        • abhi1981
                          • Aug 2013
                          • 35
                          • India
                          No, the screen is not emitting any glow when seen in the dark. I used a copper wire as a jumper. Please see picture.
                          Earlier, why did the TV start working after several on/off attempts? I didn't check all the capacitors with a meter, just visually checked for any bulges.
                            If it was intermittent, as you have said, I would suspect the control board, especially as the test patterns are not working. It may be a good idea to check all connections first, and inspect for obvious cracked solder joints on the Y-sustain and Z-sustain, those are the largest left and right hand boards.
                            • abhi1981
                              • Aug 2013
                              • 35
                              • India
                              OK. I will check all the connections and let you know in a couple of days.
                              • abhi1981
                                • Aug 2013
                                • 35
                                • India
                                I left the set switched on for some time and I noticed that some parts were warm (marked in red) and the other were cold (marked in blue). Only the yellow transformer on the YSUS board was warm (it is getting some current) and all the heat-sinks were cold - does that mean something is wrong in that area of the board ???? Please advise.
                                  If the panel isn't lighting up, it doesn't draw power. This usually means things on the sustain boards won't warm up. The transformer powers some other stuff on the sustain board which does draw power, so it does warm up. You could try using a hair dryer, or freeze spray, to warm up and cool down parts, to see if you can get the TV to work again temporarily.
                                  • abhi1981
                                    • Aug 2013
                                    • 35
                                    • India
                                    Didn't find any freeze spray, and warming up didn't help either. Please advise what to do next.
                                      Remove the Y-sustain and Z-sustain, and inspect the solder joints around the transistors. See any cracks?
                                      e.g.
                                      • abhi1981
                                        • Aug 2013
                                        • 35
                                        • India
                                        The solder joints are fine.
                                        • PNI E.
                                          tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                          by PNI E.
                                          hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                          02-20-2025, 08:36 AM
                                        • koby058
                                          vostro comes up with back light but no picture
                                          by koby058
                                          Hi people!!
                                          The owner said it showed bad picture once in a while (attached)
                                          I see that there is back light but no picture.
                                          I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                          Also attached schematic and BDV
                                          LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                          07-13-2025, 01:03 PM
                                        • KYBOSH
                                          Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                          by KYBOSH
                                          Saved this beast from the landfill this weekend.
                                          Manfactured July 2013 in Mexico.
                                          I love working on plasma TVs.
                                          Its been a while but I was lucky enough to find 2 this week.
                                          The TV powers on and stays on but no picture. Havent checked for sound yet.
                                          No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                          Will start troubleshooting tonight.
                                          10-17-2024, 01:17 PM
                                        • SluggerB
                                          Panasonic TH-50PX80 killed by lightning strike, help me save her!
                                          by SluggerB
                                          Yes it's a 17 year old Panasonic plasma!
                                          I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                                          06-04-2025, 07:02 PM
                                        • HarleyFool
                                          Troubleshooting Samsung PN60E550D1FXZA Plasma TV
                                          by HarleyFool
                                          I have a Samsung 60-inch plasma TV, model PN60E550D1FXZA with factory remote. When cold, the TV will turn on and operate normally. After operating for longer than 30-60 minutes, if the set is turned OFF and then back ON, it will turn back ON, but there is no picture (screen remains black). I can confirm set is ON because I can hear audio from the speakers when I operate the VOLUME UP/DOWN control on the remote. If I allow the TV to rest (cool), it will eventually turn back ON with picture restored. That may take an hour or overnight.
                                          I have removed the back of the TV and looked...
                                          12-21-2021, 02:40 PM
