LG 42" Plasma 42PJ560R - no picture
    Re: LG 42" Plasma 42PJ560R - no picture
    Well, this is difficult, do you have any access to an oscilloscope?
    • abhi1981
      • Aug 2013
      • 35
      • India
      No, I don't have an oscilloscope.
      One more thing, the green LED doesn't glow on the control board.
        Not at all, no flashing etc.?
        • abhi1981
          • Aug 2013
          • 35
          • India
          No, nothing at all. It used to blink when the set was working. Now, it doesn't glow at all.
            Hmm. Johnboy on this forum had a problem with the control board on the American version of this TV. Possibly the same issue?
            • abhi1981
              • Aug 2013
              • 35
              • India
              #26
              How can I check the control board ?
                The jumper before should have worked if the control board was OK, but that may also be caused by bad sustain boards. However, I think the LED would still blink if there was an error, it just may only blink a few times.
                • abhi1981
                  • Aug 2013
                  • 35
                  • India
                  #28
                  So, should I check the YSUS board? Could a bad YSUS board cause the LED to stop blinking?
                    The LED should blink at least once, if not several times, before shutting down. Assuming that the YSUS and ZSUS are isolated while you check LED, which I think you did previously?
                    • abhi1981
                      • Aug 2013
                      • 35
                      • India
                      #30
                      I will check it again. How to isolate the YSUS and ZSUS boards?
                        Just disconnect the power from the power supply.
                        • abhi1981
                          • Aug 2013
                          • 35
                          • India
                          #32
                          I did like you said. The LED did not blink even once and a sort of sparking electrical noise (like when you are tuning a radio) was coming from the power supply board. It disappeared when I restarted the set after reconnecting the power to the YSUS.
                            Originally posted by abhi1981
                            Vs=203v
                            va=59v
                            ^Previously you made those measurements... was that with the Y-SUS and Z-SUS connected?
                            • abhi1981
                              • Aug 2013
                              • 35
                              • India
                              #34
                              Yes.
                                I would suspect the control board is bad.
                                • abhi1981
                                  • Aug 2013
                                  • 35
                                  • India
                                  #36
                                  How can I test the control board?
                                    You can't, easily. There are some voltage regulators on it,
                                    https://www.badcaps.net/forum/showthread.php?t=22231
                                    but that's it.
                                    • abhi1981
                                      • Aug 2013
                                      • 35
                                      • India
                                      #38
                                      Can it be possible that there are bad capacitors on the YSUS board that is causing the display to go black- a common problem with LG TVs. As I earlier said that the TV used to start with a black screen and started working in a single on/off try and the number of tries increased with time . Maybe the logic board is not giving any test pattern because of this.
                                        As I said, that is unlikely, because from what I know about LG control boards is they will attempt a few cycles, blinking the LED, before giving up due to fault detection.
                                        • abhi1981
                                          • Aug 2013
                                          • 35
                                          • India
                                          #40
                                          By blinking LED do you mean the red power led or the green control board led. The red power led never blinks , it lights up and fades out as the set powers on-- just like normal operation.
                                          • PNI E.
                                            tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                            by PNI E.
                                            hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                            02-20-2025, 08:36 AM
                                          • koby058
                                            vostro comes up with back light but no picture
                                            by koby058
                                            Hi people!!
                                            The owner said it showed bad picture once in a while (attached)
                                            I see that there is back light but no picture.
                                            I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                            Also attached schematic and BDV
                                            LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                            07-13-2025, 01:03 PM
                                          • KYBOSH
                                            Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                            by KYBOSH
                                            Saved this beast from the landfill this weekend.
                                            Manfactured July 2013 in Mexico.
                                            I love working on plasma TVs.
                                            Its been a while but I was lucky enough to find 2 this week.
                                            The TV powers on and stays on but no picture. Havent checked for sound yet.
                                            No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                            Will start troubleshooting tonight.
                                            10-17-2024, 01:17 PM
                                          • SluggerB
                                            Panasonic TH-50PX80 killed by lightning strike, help me save her!
                                            by SluggerB
                                            Yes it's a 17 year old Panasonic plasma!
                                            I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                                            06-04-2025, 07:02 PM
                                          • HarleyFool
                                            Troubleshooting Samsung PN60E550D1FXZA Plasma TV
                                            by HarleyFool
                                            I have a Samsung 60-inch plasma TV, model PN60E550D1FXZA with factory remote. When cold, the TV will turn on and operate normally. After operating for longer than 30-60 minutes, if the set is turned OFF and then back ON, it will turn back ON, but there is no picture (screen remains black). I can confirm set is ON because I can hear audio from the speakers when I operate the VOLUME UP/DOWN control on the remote. If I allow the TV to rest (cool), it will eventually turn back ON with picture restored. That may take an hour or overnight.
                                            I have removed the back of the TV and looked...
                                            12-21-2021, 02:40 PM
