lg 42pw450t , not coming on
  • pauluk00
    • Jul 2013
    • 29
    • united kingdom
    Hi have a lg 42pw450t , was not coming on ,, changed the ysus board and it came on with a loud buzzing noise, and it was getting hot on the side of the ysus, so thought i,d do a factory reset, after i did that the tv did not come on again ,, accept when i unplug the ysus board , can some tell what causing this and how to fix it
    many thanks
  • capkid
    • Oct 2010
    • 1339
    Re: lg 42pw450t , not coming on
    I have a couple questions:
    (1) After you replaced your Y-Sus, besides the buzzing, was your TV functioning normally?
    (2) After the factory reset, when the TV turns on with the Y-Sus unplugged, are you able to hear sound?
    Hopefully, you don't have a bad panel, but it could just be a bad Y-buffer. Do you have pics of the circuit board layout?
    LG Plasma Mal-Discharge Correction Service
    • pauluk00
      • Jul 2013
      • 29
      • united kingdom
      yes after i replaced the y sus tv worked worked normal ,, (2) after a reset it resets nothing was tuned in ,,so didnt hear anything ,,
      but i,ve sent you 2 pics ,,
      • capkid
        • Oct 2010
        • 1339
        When you say that you did a reset, what did that involve?
        • pauluk00
          • Jul 2013
          • 29
          • united kingdom
          went into the menu , and pressed the factory reset
            In a dark room, can you see a glow emitted from the screen?
            • pauluk00
              • Jul 2013
              • 29
              • united kingdom
              hi tom , no there no glow in the dark
                You may have a bad (cracked) plasma panel -- especially if you are hearing a loud buzzing sound.
                Does it sound a bit like this?
                http://www.youtube.com/watch?v=-iAm82lhky4&t=1m10s
                • pauluk00
                  • Jul 2013
                  • 29
                  • united kingdom
                  no tom is isnt cracked , as i changed the ysus it came on for 10 to 15 mins with a perfect picture , but it was buzzing towards the ysus and it was getting hot where the ysus board was , so did a reset , then wouldn,t come on ,,,,
                  do have another problem with a samsung ps42q96hd ,, tv comes on with no picture ,if you turn the light out ,you can see a slight glow to the screen , any idea,s, thanks tom
                    Put the Samsung in a separate thread.
                    I would suggest your Y-sus was OK but some panel voltages were wrong causing excessive Y-sus heat, or there is a panel fault like a shorted electrode..
                    • pauluk00
                      • Jul 2013
                      • 29
                      • united kingdom
                      would it the logic board
                        I doubt it, are you talking about the LG?
                        • mikeylittle
                          • Sep 2014
                          • bournemouth
                          hello i have the same TV a Samsung 42pw450t and when i turn it on the red standby light just fades out and nothing happens and i was wondering if you fix yours???
                          • mikeylittle
                            • Sep 2014
                            • bournemouth
                            sorry it is a ( LG 42PW450T....)
                            • badge
                              • Jan 2016
                              Appologies for bringing up an old thread, but I am having the exact same issues with my tv.
                              I've not replaced anything yet. Did pauluk00 fix your tv in the end?
                              Is it ok to tag on the end of this thread or should I start my own new one?
                              Thanks.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Whats the fault ? Normally on these sets Ysus failure is caused by cold solder joints on the ERC coil on the Zsus.
                                • badge
                                  • Jan 2016
                                  Thanks for the speedy reply.
                                  When I press the red button to switch the tv on it tries to power on but reverts back to off. I can hear a clicking sound when this happens.
                                  How would I test for a ysus failure?
                                  Thanks.
                                  • masterm
                                    JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
                                    by masterm
                                    TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
                                    Problem with TV:
                                    - Netflix stopped working so i tried to do factory reset from the TV menu.
                                    - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
                                    - After waiting for some time, the TV went into a boot loop.
                                    - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
                                    04-30-2024, 03:03 AM
                                  • sheffieldyorky
                                    ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                                    by sheffieldyorky
                                    Hey there people
                                    While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                                    This is what I tried, but not in any order.
                                    Google
                                    YouTube
                                    BIOS
                                    Command Prompt (administrator privileges)
                                    On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                                    10-25-2025, 02:22 AM
                                  • mon2
                                    Hisense 55Q9G Android reset / factory firmware reload
                                    by mon2
                                    Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
                                    After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again....
                                    01-03-2024, 10:25 AM
                                  • pfrcom
                                    Reset/erase Hynix SC210 to factory default
                                    by pfrcom
                                    Some Googling made this seem straightforward, but it ain't necessarily so:
                                    First try was Hynix Drive Manager, supposed to be able to do PSID reset
                                    In Win7 x86 context, what shoddy software – this greeted me first time I clicked it from Start menu:
                                    After wild goose chase triggered by the OpenGL bit, I tried swapping graphics cards until penny dropped when it still objected to a Radeon HD3450
                                    How I got it work:
                                    1. Command prompt
                                    2. Change to install directory \Program Files\SK Hynix Drive Manager
                                    3....
                                    04-23-2022, 07:30 AM
                                  • LEONARDO DE FREITAS
                                    Chinese multimedia crashes on the home screen, could someone help with the software or factory reset?
                                    by LEONARDO DE FREITAS
                                    Hello everyone, I have 2 multimedia systems with a 9-inch screen that turns on and only stays on the Android screen. It is very likely a software update. I have 2 software programs here but the multimedia system does not start the installation. Has anyone encountered this problem? I would be grateful if you could help.
                                    04-18-2025, 09:58 AM
