lg 50pc1da grey flickering screen
  • pauluk00
    • Jul 2013
    • 29
    • united kingdom
    hi all i have a a lg 50pc1da plasma , tv comes on but its just a grey flicker screen , is it the y sus board or the buffer board that is faulty , could any body help please
    Re: lg 50pc1da grey flickering screen
    Buffer+ERC IPM on Y-sus is usually the cause of this fault.
    • pauluk00
      • Jul 2013
      • 29
      • united kingdom
      thanks tom for your reply ,, i,m just a novice at repair is the ERC IPM under the heatsink on the y sus
        Yes, there may be two IPMs. The ER IPM is the one near the coiled inductors -- little ~1-inch loops of wire I believe on this set.
        • comptek
          • Aug 2013
          • 606
          • uk
          would it be the buffer and the ER-IPM where can i get the ER-IPM from or what is the number for it anyone know ?
          thanks
          Gary
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            thanks
            Gary
            Desolder the IMP first buddy and then unscrew it from the heatsink. The Pn is written on the top of it. Also have you checked the sustain voltages ?
            • comptek
              • Aug 2013
              • 606
              • uk
              no mate i did the power supply all 10 caps as they were bulged
              i told my mate i would look into the fault just getting pointers at the moment really
              • comptek
                • Aug 2013
                • 606
                • uk
                how much are they for the IPM's rough ball park
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  YPPD-J016C, YPPD-J017C as I recall, cant remember which is the SUS IPM or ERC IPM....
                  Symptom could well be either or with them, and could be the ones on either board--Just to confuse!
                  Best way to tell, Listen closely--To which one 'Ticks'
                  TELEFIX
                  • comptek
                    • Aug 2013
                    • 606
                    • uk
                    many thanks Alastair
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • DrvLikHell
                      Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
                      by DrvLikHell
                      Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
                      The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
                      07-05-2024, 02:54 AM
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
                    • RetroComputingGrotto
                      LG 42LN540V LED Backlight Flickering After Replacement When Connecting The Screen
                      by RetroComputingGrotto
                      This TV has been on the wall in our reception area for around 10 years and the other day the backlight failed. You could see a feint picture so we knew the screen was OK. I took the TV apart to get to the failed backlight and inject voltage in to each half of the LED strips to identify which ones had failed and 4 needed replacing. I ordered a set off of Amazon and they arrived the next day.
                      On fitting the new LED strips I plugged in the TV was blinded by the light!!
                      It was only when I partially put it all back together (including the screen) that...
                      10-23-2024, 04:17 AM
                    • russianbar
                      SONY KD-65XE7002 Screen Flicker
                      by russianbar
                      This isn't my video but it's a fair representation of the fault I have, starts with slight screen flicker as the set warms up which happens every 5 seconds or so that gets more regular until more or less constant https://www.youtube.com/watch?v=Un8cAjUtOvA was thinking T-Con but open to any other ideas as seems to be quite a common fault on these
                      04-10-2025, 03:11 PM
