Samsung_LN-T1954H HDTV Look at my pictures tell me what you think is going on
  • Bubbsy 2002
    • Nov 2010
    • 56
    Hi All,
    Found this Samsung TV LN-T1954H in garbage and was suprised there was a picture.
    It has some sort of overlay on the left side from top to bottom, about 2 inches wide aprox.
    Look at my pictures tell me what you think is going on here, please.
    Thanks,
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Samsung_LN-T1954H HDTV Look at my pictures tell me what you think is going on
    oh tab-bond issue those are tricky i can tell you what it is but not how to troubleshoot it.
    its the little ribbon cables that connect the circuitry to the glass LCD panel and if that get damaged your going to have a tough time fixing it.
    Follow the white rabbit.
      Tab bonding problem or the IC for the TFT drive which is on the flexible ribbon cable between the LCD glass panel and the PCB is dead.
      • Bubbsy 2002
        • Nov 2010
        • 56
        It looks like this monitor was butchered, from a previous repair.
        What should I look for in regards to the tab bonding is it possible to repair it, and if so how might I do this?
        Thanks for the reply.
        • Bubbsy 2002
          • Nov 2010
          • 56
          The actual cable does not look damaged, but I may be wrong.
          Thanks,
          • Glitcher
            • Mar 2013
            • 673
            • USa
            There is no fix for tab bonds if they go bad. Most of the time the panel has to be replaced. But if you're lucky, if you put pressure on where the tab bond connects to the panel it may fix the problem due to a slightly loose tab bond.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              ^ exactly but i haven't had much luck with that
              • bohaboha
                Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                by bohaboha
                Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                anyhow i couldn't t read anything else
                the backlight is on strong and the screen does not get dark or very dark but no pictures
                the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                01-02-2025, 08:04 PM
              • valvashon
                LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                by valvashon
                The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                11-24-2024, 12:08 PM
              • 2elw
                SVOD4 PCB pictures + parts
                by 2elw
                Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                GW1N-UV9UG169C6/I5 FPGA - Its a...
                07-04-2025, 12:23 PM
              • grimacelord
                Component Identification
                by grimacelord
                Hello. I am working on a circuit board that is part of a motorized HDTV lift. The circuit board belongs to the controller component that tells the motor to either raise or lower the HDTV height.
                The controller started sparking when the 29V power supply was attached and the green light on the power supply would go out as soon as it was plugged into the controller board. This indicated a shorted component and I was able to identify which component it is that is causing the short. When I remove this component, the short is cleared.
                The problem is finding a replacement component....
                06-10-2025, 02:00 PM
              • VitalComputing
                Taking Pictures Of Large Circuit Boards
                by VitalComputing
                Hi friends,
                I am trying to take good quality pictures of rather large desktop motherboards for a project I'm working on. I had a brilliant idea of scanning them with a flatbed scanner I have but it only focuses on the bits of the board that are flush to the scanning glass. And the through hole components tend to lift the main board from the scanning glass. Everything else just looks out of focus. So it seems that that option wont run.
                I have been capturing the images with my iPhone 11 and it's okay but wont capture the whole board. I have to grab it in sections and...
                11-22-2022, 04:15 PM
