Sharp Aquos LC-46A77M Power Problem
+ More Options
Posts
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Re: Sharp Aquos LC-46A77M Power Problem
    Edited
    • DjKrish
      • Oct 2012
      • 354
      • SG
      Originally posted by budm
      How about when the TV is turn off (since this is STBY power supply, it is always running the minute you plug the TV into the AC outet)?
      The standby circuit voltage only shows when the relay clicks. When the relay clicks off, the voltage goes off too. I power on, picture comes, sound comes, then brightness slowly fades down and goes higher then relay clicks power shuts off. No more standby voltage. Can hear some weird buzzing grinding noise from the big capacitor during the brightness fading in n out. I can see the 60v to the backlight control board from the smps decreasing from 60v to 55v even without the socket plugged in.
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • j120975
        Sharp aquos lc-40le820e power on problem
        by j120975
        Good afternoon to all of you. First of all sorrybfor my bad English. I have a sharp aquos tv ,and i m dealing this problem. If i leave the power cord disconnected,then it starts normally for one minute approximately. After that the tv restarts and only the touch panel lights working for about 10 seconds and only 1-2 seconds lights up the led panel. After that loop again. No signal lights in center. I think probably is a power supply problem . I can see 5 v ,13.3v in 4 pins . I m a mobile technician and i can follow your instructions if you yave some suggestions. Thank you in advance.
        04-09-2021, 09:51 AM
      • Duranitron
        Asus x512dk rev 2.1 power on problem
        by Duranitron
        When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
        Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
        11-26-2024, 10:22 PM
        Mitsubishi CNC switching power supply board dead / relay board bad diode failure
        by sam_sam_sam
        I was working on this CNC machine today found no keyboard functioning no control relay powering on
        The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
        Found shorted diodes on main controller relays there are 3 of them that...
        01-07-2023, 05:43 PM
      • EazyBone
        LG OLED55C9PUA power problem
        by EazyBone
        Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
        Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
        I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
        The power supply to t con is different story.
        This...
        06-23-2023, 07:43 AM
