Philips 42PF7320A Plasma
  • ilikesteel
    • Jul 2012
    • 284
    • usa
    I have a chance to buy this set cheap. here's what the owner says,
    "This TV was working until HORIZONTAL LINES started appearing. A short while later, the screen went black with bits of static. Selling AS-IS".
    What's the consensus on a problem like this? can it be the plasma panel or a possible fix if it's a resetting of a connector, circuit board problem, or possibly a PS problem? I haven't messed with a plasma before. point me in the right direction.
    Thanks guys,
    frank
    Re: Philips 42PF7320A Plasma
    Top to bottom?
    Left to right?
    Top to bottom: Bad plasma panel
    Left to right: Buffer board
    • ilikesteel
      • Jul 2012
      • 284
      • usa
      Tom66
      owner said horizontal, then black screen. you think it's worth a shot if it's not vertical lines? I sent the owner an email requesting a little more specifics about the set and what actually happened. do you think it's a set worth repairing?
      thanks,
      frank
      • ilikesteel
        • Jul 2012
        • 284
        • usa
        more info from the owner:
        The lcd panel is perfect. Power is perfect, no red lights, all green. Sound works. The TV was working fine, then the top half went dark and the bottom had horizontal line spaces in white/gray. After a few restarts, that went as well. The TV is black but it flickers in multiple spots of the screen a colored static randomly. I red about the y-sus boards going bad on this model. Lots of successful fix-it stories if you google it. I just don't have the time to order parts and fiddle with it.
        what do you guys think? run out and buy it?
        many thanks to all,
        frank
          It could be a buffer board plus Y-main failure.
          • ilikesteel
            • Jul 2012
            • 284
            • usa
            Tom66,
            Is that a green light to buy it? looks like boards may be available on ebay and perhaps other sources. never had a plasma but would like to try one. I'd like to pull the trigger on this one before someone jumps on it.
            Thanks so much for you comments,
            frank
              It is a difficult, but far from impossible problem to fix. It depends entirely on your skill level.
              • ilikesteel
                • Jul 2012
                • 284
                • usa
                skill level is pretty good, can solder and use a meter. fixed a lcd monitor and a lcd TV with PS problems. I may just get this one for the experience.
                thanks Tom66
                frank
                • celiabrown
                  Issue with Plasma Philips 37inch chassis FTL2.1
                  by celiabrown
                  Hello guys,
                  My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                  Can someone has any symptom like this ?
                  Thanks​
                  05-09-2024, 10:56 PM
                • G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                  by G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                  It does power up when pressing the power button.
                  I already try the power button while plugin the plug with no result.
                  Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                  Could this be an PSU or eMMC issue ?
                  07-19-2025, 03:43 AM
                • double_DD
                  Philips curling iron - is this a common AC cable?
                  by double_DD
                  Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                  As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                  Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                  08-18-2025, 10:04 AM
                • janos6662000
                  Philips 47PFS7509/12 LCD TV problem
                  by janos6662000
                  Hi
                  I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                  When i applied cable signal to check image, i had normal picture, but TV was restarting.
                  I downloaded original firmware and applied the update, but the problem remained.
                  From a colleague i received a "factory package software" which is a lot bigger.
                  I made another firmware update, but still did not solve the problem.
                  Somewhere on the way the error got worse, because at the moment the...
                  08-12-2025, 12:54 PM
                • aidanmo
                  Philips 43PUS7506/12 - Loud blown out sound
                  by aidanmo
                  I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                  I thought maybe the speakers got damaged, so I replaced them - no dice.
                  • Using the internal speakers, it always happens.
                  • Using the headphone jack, it never happens.
                  • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                  02-28-2025, 03:13 PM
