Philips 42PF7320A Plasma
  • ilikesteel
    • Jul 2012
    • 284
    • usa
    I have a chance to buy this set cheap. here's what the owner says,
    "This TV was working until HORIZONTAL LINES started appearing. A short while later, the screen went black with bits of static. Selling AS-IS".
    What's the consensus on a problem like this? can it be the plasma panel or a possible fix if it's a resetting of a connector, circuit board problem, or possibly a PS problem? I haven't messed with a plasma before. point me in the right direction.
    Thanks guys,
    frank
    Re: Philips 42PF7320A Plasma
    Top to bottom?
    Left to right?
    Top to bottom: Bad plasma panel
    Left to right: Buffer board
    • ilikesteel
      • Jul 2012
      • 284
      • usa
      Tom66
      owner said horizontal, then black screen. you think it's worth a shot if it's not vertical lines? I sent the owner an email requesting a little more specifics about the set and what actually happened. do you think it's a set worth repairing?
      thanks,
      frank
      • ilikesteel
        • Jul 2012
        • 284
        • usa
        more info from the owner:
        The lcd panel is perfect. Power is perfect, no red lights, all green. Sound works. The TV was working fine, then the top half went dark and the bottom had horizontal line spaces in white/gray. After a few restarts, that went as well. The TV is black but it flickers in multiple spots of the screen a colored static randomly. I red about the y-sus boards going bad on this model. Lots of successful fix-it stories if you google it. I just don't have the time to order parts and fiddle with it.
        what do you guys think? run out and buy it?
        many thanks to all,
        frank
          It could be a buffer board plus Y-main failure.
          • ilikesteel
            • Jul 2012
            • 284
            • usa
            Tom66,
            Is that a green light to buy it? looks like boards may be available on ebay and perhaps other sources. never had a plasma but would like to try one. I'd like to pull the trigger on this one before someone jumps on it.
            Thanks so much for you comments,
            frank
              It is a difficult, but far from impossible problem to fix. It depends entirely on your skill level.
              • ilikesteel
                • Jul 2012
                • 284
                • usa
                skill level is pretty good, can solder and use a meter. fixed a lcd monitor and a lcd TV with PS problems. I may just get this one for the experience.
                thanks Tom66
                frank
                • celiabrown
                  Issue with Plasma Philips 37inch chassis FTL2.1
                  by celiabrown
                  Hello guys,
                  My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                  Can someone has any symptom like this ?
                  Thanks​
                  05-09-2024, 10:56 PM
                • G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                  by G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                  It does power up when pressing the power button.
                  I already try the power button while plugin the plug with no result.
                  Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                  Could this be an PSU or eMMC issue ?
                  Today, 03:43 AM
                • aidanmo
                  Philips 43PUS7506/12 - Loud blown out sound
                  by aidanmo
                  I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                  I thought maybe the speakers got damaged, so I replaced them - no dice.
                  • Using the internal speakers, it always happens.
                  • Using the headphone jack, it never happens.
                  • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                  02-28-2025, 03:13 PM
                • ArMaaN376
                  Samsung PS51E550 Plasma TV
                  by ArMaaN376
                  I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                  Opened TV cover & observed foll
                  a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                  b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                  c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                  How to confirm Y -Buffer board...
                  06-19-2024, 04:05 AM
                • jm1234
                  Panasonic plasma TX-P42ST50 - 6 blinks
                  by jm1234
                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                  I checked that board for any obvious faults...
                  05-22-2024, 06:59 AM
