Philips 42" 42PFL5432D/37 power light no picture please help
    Re: Philips 42" 42PFL5432D/37 power light no picture please help
    You can leave the IC in place, use 2K Ohm scale or auto range, I expect the short circuit to be at the VCC pin.
    • sunn1044
      • Sep 2013
      • 20
      • usa
      Thank u m the p/s i am working on some one give it to me I have just notice that the caps
      are 1000 micro f and it should be 1500mf would that cause for it not to get the 24v also do have to put the p/s in the tv and turn on the tv b4 u check for 24v or u can do o/side by just plug in only p/s Thank u much
      • philliesfan30m
        • Aug 2013
        • 542
        you will need to put it in and atleast ground it with 1 screw. the 1000mf caps might let it work but they should be replaced with low esr and same mf as the original ones which are 35v 1500mf i believe.
        • philliesfan30m
          • Aug 2013
          • 542
          i mean uf
          • sunn1044
            • Sep 2013
            • 20
            • usa
            Hi guys I change ic 904 ic910 zd918. D926 and still getting 1.6v to
            Inverter board I cannot get 24v any help will be appreciated
            Thank you
            • munirutech
              • Oct 2013
              • 72
              • Ghana
              #26
              hi
              for testing resistors the best way to get good results is when you take out of the circuit or you remove one end of it out of the circuit
              for the ic you do it on circuit when the power is on and if the vcc is present BE CAREFULL
              • philliesfan30m
                • Aug 2013
                • 542
                sunn can we see a pic of your board and list everything you have replaced so far?
                • sunn1044
                  • Sep 2013
                  • 20
                  • usa
                  #28
                  Well guys Thank you all for all the help I have decided to purchase a use P/S and the tv work fine I have 24v going to inverter board the problem was the p/s board
                  • PNI E.
                    tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                    by PNI E.
                    hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                    02-20-2025, 08:36 AM
                  • Rauni
                    Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                    by Rauni
                    Hello, this is my first post on this forum, and my first attempted to repair a TV.
                    My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                    Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                    Read also that we should test what happens if we...
                    10-01-2023, 12:06 AM
                  • Schwoin
                    Philips 243v5lhsb00 Monitor Picture too bright
                    by Schwoin
                    Hey everyone,
                    the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                    While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                    you can see them on the top half of the photo.
                    At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                    03-21-2023, 12:40 PM
                  • kca
                    Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                    by kca
                    Hello all ~
                    I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                    This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                    No picture. No sound.
                    I tested all the voltages coming out of the power supply...
                    10-12-2023, 05:23 PM
                  • madyoyo
                    Philips 37pfl560: Yellow picture
                    by madyoyo
                    HI.
                    I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
                    Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
                    05-30-2025, 10:16 AM
