I have a Sharp LC60E77UN that I picked up over the weekend. I'm excited about this one. It's the biggest TV I've worked on to date. The TV powers on and off with the power button. There is backlight and sound, just no picture. I suspect T-Con. The set apparently has two T-Cons, RUNTK4225TPZZ (the bigger squareish board) and RUNTK4221TPZA (the thinner board). I've found the SM, but can't find anything to help troubleshoot my no video problem, just specific inputs. Any help would be appreciated.
Sharp LC-60E77UN Good Power, Backlight, and Sound, No Pic
Tags: None
Re: Sharp LC-60E77UN Good Power, Backlight, and Sound, No Pic
The bottom board is a frame rate converter for the 120Hz feature probably.
The top board is the T-con board although it appears to use an FPGA (basically a fully customisable logic chip, not fixed structure) so its functionality may be different.
I'd check all regulators, fuses and make note of test voltages. You may want to consider borrowing the scope, as you can trace the LVDS signals and see if any are present or missing -- just a matter of seeing where they are going awry.
Several of the flat flex cables look a little dodgy, so I'd also try re-seating them.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
I'm not sure if I'll be able to get the scope anymore. It's a long story but it had an intermittent no start issue that I had nothing to do with and it seems like the EE suspects that I did something to it. I may have to buy both boards and return whichever doesn't do the trick.Comment
You may want to consider investing in one, for around $50 you can get a decent analog one. It may also be the main board though that is relatively unlikely.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Unfortunately, no. I haven't had the money to get a decent scope.Comment
You can get an analog scope for under $50
http://www.eevblog.com/2013/07/25/ee...scope-on-ebay/
which will be suitable for the diagnosis of the signals coming into and out of the t-con board.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
johnboy1313, did you find the service manual on the internet somewhere? If so, do you mind sharing the link. elektrotanya only has a 3 page tech bulletin for this model.
Thank you.Comment
I'm pretty sure I got it from Elektrotanya. I think I have it at home on my computer. To be honest, I can't be certain. If I have it, I'll break it up into smaller chunks and post it here tonight.Comment
Big download:
http://elektrotanya.com/?q=showresul...oria=&kat2=allNever stop learning
I will have a scope tonight. Once I have it, what am I looking for to determine if it's a main/scaler/t-con board issue? Is it as simple as following the 12V to the panel with the scope?Comment
You would be looking at each of the LVDS data lines between boards, you can see the differential bus (traces tight together.)
If there's no activity on those from the main board, likely main board at fault (but rare, given sound), if there's no activity on the FRC motion processor (I think that's what the middle Sharp board is) then that's bad (if it's got input coming in), if nothing coming out of T-con (and it's got input), then that's bad.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
If there's no activity on those from the main board, likely main board at fault (but rare, given sound), if there's no activity on the FRC motion processor (I think that's what the middle Sharp board is) then that's bad (if it's got input coming in), if nothing coming out of T-con (and it's got input), then that's bad.Comment
I'll be completely honest here. I have no idea what I'm trying to do here. I believe the attached is the page that lists what each pin is for the main board output to the panel. Not sure which pins to probe.Attached FilesComment
10X. You want to probe the TA1+, TA1-, TCLK+ etc. lines but you only need to probe one with a signal on it... you don't really care about what the signal is just if it is getting lost.Last edited by tom66; 09-20-2013, 03:42 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Should I connect a source? Without one, I'm getting nothing at all across any of them (from the main)Comment
It could make it easier.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I can't get the TV to change source to the DVD player I have hooked up. I can't tell if the input button just displays a menu that needs to be cycled through with the channel button or if the input button actually changes the source. With that said, there is absolutely no difference across any of the pins coming from the main. I don't really know how I should have the scope set up though. I'm not sure what the waveform would look like if there was a change.Comment
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by totofGood morning.
I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
HVDD : 7,28... -
by Superbee_dadHello Sharp TV experts
Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
> I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
> There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...01-24-2025, 11:51 PM - Loading...
