Toshiba 32BV701B loss of audio
  • signup
    • May 2013
    • 189
    Re: Toshiba 32BV701B loss of audio
    Hi
    Pin2 when sound is working is 3.35v.
    Do you think its the audio ic..I have another board with the same one on and my god they are a bit of a pain to remove.
      Ah... That's important. So when the audio is bad, the pin is definitely nearly 0V? Because that indicates a fault detected. Please double check that.
      Causes:
      * Short circuit or over-current on either speaker (possibly chafed wire, bad speaker coil: check resistance of speakers and try with only one speaker at a time)
      * DC detect fault: most likely TPA3113
      DC detect would be rare, as it would typically not be intermittent.
      Also, see if audio cuts out if the volume is low, and if it cuts out quicker on high volume.
      • signup
        • May 2013
        • 189
        [QUOTE=tom66;355334]Ah... That's important. So when the audio is bad, the pin is definitely nearly 0V? Because that indicates a fault detected. Please double check that.
        Yep defo 0.3v when sound goes
        Originally posted by tom66
        Causes:
        I have used a set of speakers from an identical set and still the same
        No tried this as best I can it doesnt matter if the volume is on 1 or full chat it seems to fail around the same sort of time from cold
          You're probably looking at swapping the TPA3113 or a new 17MB60.
          • signup
            • May 2013
            • 189
            I will have to try changing it because this by the looks of things has got an odd ball screen, I cannot see one with the same lvds connector.
              What screen does it use? Samsung? If the connector is the same, you should only need to access service menu to change LVDS mode.
              • signup
                • May 2013
                • 189
                Yes Tom its a Samsung screen but this one has got a t-con,where 90% of the others use the flat cable straight to the screen
                And dont runaway I have just made a massive schoolboy error I need help with
                • gnrlee
                  • Jul 2013
                  • England
                  #28
                  hey guys!
                  sorry to but in I also have a problem very similar to the one stated on the same make,...
                  but mine is just loss of audio through the HDMI port all the scarts and phono jacks work fine,..
                  is this just a fault with the HDMI it's self and can it be rectified just by replacing that Control Board?
                  Thank you and sorry for butting in!
                  • signup
                    • May 2013
                    • 189
                    This is getting to be a common problem on this main board, I phoned my TV repair mate yesterday and he has 2 of these with audio faults, an Alba and a Toshiba.
                    If you do go for a main then be careful matching the things up
                      gnrlee I would try a reset from service menu.
                      Press 4 7 2 5 Menu, or Menu 4 7 2 5 on remote to get to service menu then select reset ("factory reset")
                      • gnrlee
                        • Jul 2013
                        • England
                        #31
                        Cheers Tom!
                        Yeah tried that but didn't change anything!
                        and both HDMI's are the same with no audio.
                        New board then?
                          I'd try that then.
                          Crappy Toshiba Vestel... When will Tosh learn! They are running their laptop brand into the ground with re-badged "Compal" rubbish, then they run their TV and AV line into the ground... soon there will be no more Toshiba! All at the expense of a quick buck & payout for some CEO.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #33
                            Common issue on these is 4 little 470nf 6.3v ceramic capacitors that provide the feed back for this Ic failing, you can buy repair kits on ebay however they are very hard to install. I will link one for you.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #34
                              Edit: Doh just seen how old this thread is !
                              • satinser
                                • Oct 2012
                                • 214
                                • uk
                                #35
                                Sorry to resurrect this post. ReeceyBurger123 you appear to infer that its just the smd caps that fail and need replacing? Have you found that the chip also needs replacing? Or is it included in the kit on the basis that it might fail. I havnt actually used this kit in the past as been able to get a replacement board but am unable to get hold of a board for the Sharp LC-32D12EA which has inter audio on 17MB60 so looks like the kit with ultra small smd caps is only option.
                                • comptek
                                  • Aug 2013
                                  • 606
                                  • uk
                                  #36
                                  can you supply a photo of the white label on the card slot i will see if i have one
                                  • satinser
                                    • Oct 2012
                                    • 214
                                    • uk
                                    #37
                                    Many thanks for your reply. I gave the possible customer a price based on the fitting the kit and he hasn't got back to me. Thanks though for your kind offer of looking into it for me.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #38
                                      Also try resetting the Tv first before replacing the caps.
                                      • samson7point1@yahoo.com
                                        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                        by samson7point1@yahoo.com
                                        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                        The player processes the audio signal using two different reference frequencies. The "R"...
                                        04-30-2024, 11:22 AM
                                        09-06-2024, 05:27 AM
                                      • String2016
                                        TOSHIBA L755 NO audio problem
                                        by String2016
                                        I have here toshiba l755 laptop the problem is no audio device detected on windows tried installing drivers and tried also replacing audio chip still same issue. anyone encounter this please help
                                        03-04-2023, 01:58 AM
                                        09-06-2024, 05:59 AM
