Mitsubishi LT 40151
  • ilikesteel
    • Jul 2012
    • 284
    • usa
    Mitsubishi LT 40151
    Went to buy this used not working TV today. The problem originally was, has sound, but an all blue screen. when I showed up to the owners house, she told me her cat had knocked the TV over. It was leaning against the wall. this was a wall mounted TV that was removed from the wall bracket. (no base). when she turned the TV on, the display symptoms had changed. below is a picture of what the display looks like now with no external connections connected to it. she gave me the TV for $0.
    My question is, what does this look like, a lcd problem caused by the fall or possibly something repairable? for the original problem of has sound and a blue screen I was going to check caps on power board as a starter. however, I'm not sure what to check based on the picture.
    many thanks for this form. the knowledge base is incredible.
    frank
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Mitsubishi LT 40151
    broken screen, time to part it out.
    at least it didnt cost you anything.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • ilikesteel
      • Jul 2012
      • 284
      • usa
      I thought it may be a bad lcd screen. this would have been a good one to repair if it was only bad caps.
      thanks for the response.
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
