Samsung LE37R87BD tv text remaining on screen
  • darkoverlord
    • Mar 2013
    • 9
    • united kingdom
    I have a Samsung LE37R87BD tv has strange issue, firstly caps on power board was buldging so generall clicking on/off taking 20 mins to turn on. Replaced these and tv powers up as it should, but now Im noticing the text is staying on the screen and slowly goes away, also screen is darker than it was before the power issues, I was going to replace the T-con board and possibly the inverter, was just seeking a little advice before doing so as worst case maybe the panel going and dont wasnt to go to the expense of replacing boards if this is the case.
    Thanks in advance of an answer
    Re: Samsung LE37R87BD tv text remaining on screen
    Can you perhaps show a picture of the problem? Or a video? Does normal TV blur the picture?
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Did you just replace the caps that were bulging or all of them? Did you use low ESR caps?
      • darkoverlord
        • Mar 2013
        • 9
        • united kingdom
        All but 3 of the caps on power board were noticeably blown, reading on esr was still ok on remaining ones but replaced all as a precaution, used same brand as I have done in past for all other tvs I have repaired, Panasonic and Rubycon. Camera doesnt pick up the issue, it seems to be the white text or still images from the menu that stay on screen, it doesnt stay permanently and can not be seen from all angles, but square on to it can be seen by eye, also picture seems to be dark even with brightness on 100% and backlight on 10, im thinking the inverter may be failing, but dont want to replace if it is the panel / backlight that is starting to fail, TV is around 3 years.
          It is more likely to be panel - probably tab bonds. On back of LCD panel there will be a sticker like CHI MEI OPTOELECRONICS, CHUNGWHA PICTURE TUBES, AU OPTRONICS, SAMSUNG etc. indicating who made the actual LCD glass, what does it say?
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • Chrissygizmo
            samsung galaxy ao2s very temperamental after screen replaced
            by Chrissygizmo
            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
            Ive eventually managed to get it on and working but it's very temperamental...
            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
            05-26-2024, 12:05 AM
          • Kiberge
            Samsung LH82QENELGC/EN Help needed - Static line on screen
            by Kiberge
            HI guys!
            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
            04-22-2024, 11:28 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • arbitarytwist
            Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
            by arbitarytwist
            Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
            Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
            03-01-2025, 01:16 PM
