LG 50PC3D Power Issues.
  • ZRICE28
    • Jul 2013
    • 19
    Hello everyone. I'm new here and came across a few other posts from members who seem to have been experiencing similar problems to what I am. They all seemed open ended, and I haven't found a solution yet. I'm to tv repair, but learn quickly. I have had luck in the past with simple capacitor replacement on a few other tvs. This one seems to be a bit trickier.
    I picked up a lg 50pc3d. It flashed three times and powered off. I bought a cap kit and replaced 9 10v 3300 uf, and 3 others, whose values I don't have in front of me right now. Same problem, turns on, and shuts back off, now the optical light on the back comes on though. I unplugged both of the other boards from the power supply, same result. I'm lost now. Thank you in advance.
  • ZRICE28
    • Jul 2013
    • 19
    Re: LG 50PC3D Power Issues.
    I found some of tom66's posts regarding ac detect. Just checked that, and the voltage was 4.85 and only dropped to 4.83 when it clicked itself off. Same thing with the ysus board unplugged.
      And with Z-sus unplugged?
      • ZRICE28
        • Jul 2013
        • 19
        Doesn't z come from y? 5v off of the power supply going to ysus is only 1.3. V-a is1.0 and drops. V-s is.068 and drops.
          With all boards unplugged except main board, do you have 5V/Vs/Va?
          • ZRICE28
            • Jul 2013
            • 19
            with everything unplugged, nothing at 5v. v-a is .1 and dropping, v-s is .06 and dropping. y board and everything else plugged back in, .668 and holds at 5v, .50 at v-a and drops quickly, nothing at v-s. that is checking the pins leading to the ysus board. the smaller gauge wires at the bottom of the board that run down to where I tested dc detect, 5v is at 4.99
              OK, can you locate the pin marked PS-ON and acquire a couple of 470 ohm resistors for a test that can be done?
              • ZRICE28
                • Jul 2013
                • 19
                I will look for ps-on when I get home tonight. Do the resistors have to be 470s? I could pull some resistors from another board that I have laying around. Or should I stop and buy a few 470s on my way home?
                  Anywhere from 100 ohm to 470 ohm should be usable.
                  • ZRICE28
                    • Jul 2013
                    • 19
                    I have the resistors. All I see marked on the main and power supply boards are rl-on vavs-on and 3.3v-on
                      Can you post a picture of the particular connector?
                      • ZRICE28
                        • Jul 2013
                        • 19
                        I think this is the connector you're talking about.
                          OK, please connect resistor from S-5V to RL-ON and M5V-ON. You should have +5V main and other voltages like 19V available. You should also hear a click from the PSU.
                          • ZRICE28
                            • Jul 2013
                            • 19
                            Like this?
                            • ZRICE28
                              • Jul 2013
                              • 19
                              Same as this right?
                              • ZRICE28
                                • Jul 2013
                                • 19
                                Ps stays running, but nothing on the screen.
                                  Yes, but do you get +19V, etc.? Vs/Va should be missing for now.
                                  • ZRICE28
                                    • Jul 2013
                                    • 19
                                    19.17 v, 4.94 v, v-a .093, no v-s, fan is not running.
                                      OK, now take an additional resistor to VS ON in the same manner, do Vs and Va come up? Y-sus and Z-sus to be disconnected for now.
                                      • ZRICE28
                                        • Jul 2013
                                        • 19
                                        I think I have it right. It's hard to get the resistors to stay in place in such a tight spot. The ps keeps wanting to turn off if the resistors aren't positioned just right. v-s is .033 drops slowly, v-a is .265 and drops faster, 19v is 19.19, 5v is 4.97.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • zlr8r
                                          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                          by zlr8r
                                          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                          Ill try and give as much info as I can.
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                          Then it started getting weirder!
                                          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                          12-12-2023, 09:31 PM
                                        • sli4
                                          Original NES power issues
                                          by sli4
                                          I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
                                          I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
                                          Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
                                          On the big blue connector I get...
                                          11-28-2024, 12:52 PM
