Sharp LC-52LE830U Lightning Strike No Standby
  • johnboy1313
    • Nov 2012
    • 1959
    A friend's dad stopped by and dropped this off for me. No LED on the front when plugged in. 166V across the big cap. Nothing else. No voltages present at any of the pins on the connector to the main board. This set was the victim of a lightning strike. Looks like the PSU is fried, I suspect the main board is probably no good too.
    Power supply pictures from ShopJimmy. I can get closeups of specific areas if needed.
    http://www.shopjimmy.com/sharp-runtk...t-inverter.htm
    I've attached the useful part of the SM. Everything else is teardown, setup, main board schematics, or parts lists.
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Sharp LC-52LE830U Lightning Strike No Standby
    Bump
      Check voltage across any small electrolytic caps on the primary, one is probably a start up cap.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        ^ I second that.
        By the sound of it, either the standy supply is toast, the mainboard, or both have been toasted.
        Muh-soggy-knee
        • johnboy1313
          • Nov 2012
          • 1959
          I checked voltages across every electrolytic cap on the board. The only ones with any voltage are the 3 long 450V caps that show 166V across each one.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            There is a 7-pin DIP chip near that "Delta" logo. (Delta is a PSU making company)
            There are two small electrolytic capacitors near the chip. With the power supply unplugged, can you please measure the resistance across these two capacitors?
            Also some more up-close pictures of that area would be nice. (Front and back of the board, mind you!)
            Muh-soggy-knee
            • johnboy1313
              • Nov 2012
              • 1959
              The brown 63V, 47uf cap above the A of the Delta logo starts at 0 and immediately jumps until it steadies out around 150kΩ. The small black 100V, 1uf cap above the triangle shaped Delta symbol starts at 0 and quickly jumps until it steadies out around 56Ω. I'll try to get better pics this afternoon.
                I'd look at the 100V/1uF cap -- trace the IC connected it.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Try removing the 7-pin chip, and see if the resistance across the 1uF capacitor is much higher.
                  Will need some good pics of that area of the board, front and back.
                  Muh-soggy-knee
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    The issue is probably with the small 7-pin chip, since it is highly likely that is controlling the standby power supply. OP stated that the 5v standby isn't even present.
                    Muh-soggy-knee
                      That'd be my guess too. It's relatively common for the internal Vcc path to short, especially if the in-built MOSFET breaks down transiently (putting 400V on the Vcc.)
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        The IC is labeled...
                        1129
                        TNY264PN
                        94599E
                        I'm not really sure how to test it. I think this is the datasheet.
                        https://cdn.badcaps-static.com/pdfs/...bb528125a8.pdf
                        Here are some pics. I hope they help. The first pic is the back of the IC.
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          Here's the other side of the board. Again, the first pic is the area in question.
                            Check the voltage on drain, the exposed pin 8, negative lead on big 400V cap negative.
                            Check the voltage on BP, the first pin on the device. Should be 5.8V in operation.
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              Pin 8 = 0V
                              Pin 1 = 166V
                              Both measured with the black lead on the big cap.
                                My bad. Please check pin 5 which should be drain, or around 160V.
                                Looks like the IC is bad though with an internal short from drain to Vcc.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Yep that is exactly what I was thinking too
                                  Muh-soggy-knee
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    166V at pin 5 and pin 6 too if that matters.
                                      Pin 6? That is a missing pin? Do you mean pin 7 (which is the 6th counting clockwise)?
                                      • mr2013e
                                        Elc. Engineer
                                        • Jul 2013
                                        • 41
                                        • TURKEY
                                        which smps pwm controller talking about?
                                        TNY264PN
                                        if ic is bad, check the mosfet.it could be short.
                                        • Bardou Kari
                                          HP EliteBook 840 G6 – no power after lightning strike
                                          by Bardou Kari
                                          I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                                          – Charger is OK and 19V is present at the motherboard.
                                          – No charging LED, no fan, no reaction.
                                          – I don’t see any 3.3V or 5V near the coils.
                                          – Battery is unplugged.
                                          – I’m new to board repair but can use a multimeter.
                                          I added a clear photo of the board.
                                          Any idea where to start or what to check next?
                                          Thanks a lot for your help!...
                                          07-01-2025, 10:45 AM
                                        • SluggerB
                                          Panasonic TH-50PX80 killed by lightning strike, help me save her!
                                          by SluggerB
                                          Yes it's a 17 year old Panasonic plasma!
                                          I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                                          06-04-2025, 07:02 PM
                                        • SJX1290
                                          Sharp 50BL2AE stays on standby
                                          by SJX1290
                                          Hi,have Sharp 50BL2AE which is not powering, stays on stand by, White control led is permanently on, signal from remote is coming on board as well from power -mutifunctional button on back side. All power voltages seems to be ok. Backlight checked, working..
                                          Any ideas?
                                          12-10-2024, 01:17 AM
                                        • karthur
                                          Samsung UN60EH6000 wont come on after lightning strike.
                                          by karthur
                                          We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                                          I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                                          When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                                          Here is what I have checked.
                                          On the power supply board, 14pin connector:
                                          1 :12.7 Vdc
                                          3 :12.7
                                          5 :12.7
                                          7 :12.7
                                          9 :0
                                          11 :5.
                                          13 :5....
                                          11-01-2023, 06:18 PM
                                        • pbig
                                          advices for repairing Sony Bravia 32EX600 after lightning strike
                                          by pbig
                                          hi everyone,
                                          my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                                          On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                                          - the 450V/150uF capacitor voltage when plugged is normal at 394V
                                          - from connector CN6150 (15 poles)
                                          STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                                          06-28-2023, 02:43 AM
