Sanyo DP42848
  • landyboy
    • Apr 2013
    • 443
    Re: Sanyo DP42848
    Ok got the master today replaced it and same issue? Bad cffl's?
      Re: Sanyo DP42848
      That is a possibility. What is the part # on the inverter controller IC?
      • landyboy
        • Apr 2013
        • 443
        Re: Sanyo DP42848
        Looks like 02864SN
        T15695 ic
        0749c
        • EricStanicki
          • Jul 2013
          • 3
          Re: Sanyo DP42848
          _
          • seal2b1
            • Jul 2013
            • 5
            Re: Sanyo DP42848
            I have a dp42848 with the same problem. However I did notice that if I held my meter leads on the 2 wires going to the bulbs (pink and white) and powered on the tv, the picture stayed on. Looking at the back of the tv with the cover off it is the inverter on the right side. Does this mean that the inverter is bad? Is it repairable?
              Re: Sanyo DP42848
              You shouldn't stick your meter across there, you have probably damaged it due to the 3000V or so between those points.
              • seal2b1
                • Jul 2013
                • 5
                Re: Sanyo DP42848
                Don't think it damaged it or made a difference except possible showing me that it was the slave board that's bad. I measured the other one when turning the power on and during the few seconds it was one before blacking out it only went to 27V. Like I said when I hold the two leads on them and power on the TV it works fine. When removing them it goes back to what the original issue is......Inverters. Only reason I posted was to see if someone had an idea on what may be bad on the inverter at component level or a schematic so I could replace it. Probably just order the inverter kit.
                • landyboy
                  • Apr 2013
                  • 443
                  Re: Sanyo DP42848
                  I replaced both boards and it still does the same thing. I think I will take it down to the cffl level and see if I have a bad bulb or two.
                    Re: Sanyo DP42848
                    If your meter showed 27V on a 3000V output, then it has probably failed internally; continue using it at your own risk.
                    • landyboy
                      • Apr 2013
                      • 443
                      Re: Sanyo DP42848
                      OK tore it down and it appears I have a couple bad bulbs. Going to try some from my donor sets.
                        Re: Sanyo DP42848
                        Did you turn it on and see what bulbs look like?
                        • landyboy
                          • Apr 2013
                          • 443
                          Re: Sanyo DP42848
                          Ok replaced the bad bulbs and this is what I have for about 2 seconds then off. Already replaced both slave and master
                            Re: Sanyo DP42848
                            It looks like one of your boards is still bad, or there is a loose connector between one side of the lamps and the inverter.
                            • flibidy
                              Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                              by flibidy
                              I have here a Magnum IA.100 which belongs to my parents.
                              The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                              Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                              What Ive done........
                              01-01-2025, 01:26 PM
                            • bouny56
                              Lenovo E15 Nm-c421 usb-c work only in one side
                              by bouny56
                              ​Hello
                              Laptop E15 I5 10gen
                              Mb nm-c421
                              I have a problem with the usb-c power dc.
                              The motherboard start only in one side of the usb-c
                              Replace the usb-c port 2 times same problem
                              With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
                              Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
                              Can the pd controler be the fault ? Or something else maybe ?
                              Thx
                              02-11-2025, 03:15 AM
                            • howardc64
                              by howardc64
                              07-24-2025, 05:17 PM
                            • Stephen
                              A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
                              by Stephen
                              Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
                              05-29-2025, 10:35 AM
                            • JarzabekPZ
                              DELL Latitude 5520 - charging only on one side of usb-c
                              by JarzabekPZ
                              DELL Latitude 5520
                              MB: South Peak 15 MB (DDR4)
                              Charging only on one side of usb-c on both ports. I have replaced one of the ports but still the same. Checked for short, nothing is getting hot under thermovision. Usb meter is not coming on one side, on the other is coming on and showing 20V.
                              Any sugesstions where to look for fault?
                              04-04-2025, 07:15 AM
