Samsung LE32R74BDX Backlight flicker
  • signup
    • May 2013
    • 189
    Re: Samsung LE32R74BDX Backlight flicker
    Pheewww Main survived its ordeal of a brisk kick up the arse :o)
    With the resistor connected it stays at 11.4v and when the backlights boot up and the flickering starts it drops to 10.4v and stays there
      OK, so with backlights flickering, resistor disconnected, what happens to 13V line? Does it increase? What does 24V measure with and without resistor?
      • signup
        • May 2013
        • 189
        Without resistor and lights flickering 11.4v (Steady)
        With the resistor on the 24v line it drops and flutates from 17v to 0v back to 17v, obviously with 17v you can hear the BL try and start but cant
        WIthout resistor/Flickering 21.1v (Steady)
        • signup
          • May 2013
          • 189
          Hi
          Do you think its a dodgey F9222L
            Yes or bad output capacitor or CM802 assuming that new CM802 is no good.
            • signup
              • May 2013
              • 189
              Cheers Tom
              Knowing my luck it will turn out to be another bad ebay buy
              Will try a new cm802 in tomorrow and change the other caps and see how it goes
              • craigc15
                • Jun 2012
                • 53
                Did you figure out what was causing your problem?
                I have the same problem and I've tried everything suggested here with no success. I have also replaced all of the electrolytic caps on the board.
                Thanks!
                  09-07-2024, 05:50 AM
                • C152Heavy
                  Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                  by C152Heavy
                  Summary for TL-DR readers:
                  • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                  • Have obtained Samsung schematic & service documents - Can upload if helpful.
                  • Have read ALL applicable threads
                  • C1818 and CP820 replaced as low hanging fruit
                  • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                  • VCC pin (18) of PFC...
                  01-11-2023, 02:53 PM
                • fixit007
                  Samsung flicker - BN44-00932T board or else?
                  by fixit007
                  I picked up this TV that the prior owner said - just died.
                  Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                  Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                  Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                  05-04-2024, 06:14 PM
                • sansanpartida
                  Samsung QE82Q70RAT no backlight
                  by sansanpartida
                  Hi everyone!
                  Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                  My issue: No backlight.
                  Model: QE82Q70RAT
                  Type No: QE82Q70RAT
                  The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                  So hopefully, I can fix this cheaper.
                  05-22-2024, 06:56 AM
                • howardc64
                  Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                  by howardc64
                  TV was fixed just after removing Samsung's rear snap cover.
                  This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                  Maybe PSU->backlight connector didn't have a good contact?...
                  07-23-2025, 12:34 AM
