Samsung LE32R74BDX Backlight flicker
  • signup
    • May 2013
    • 189
    Hi
    Got this one and it was dead traced the fault to the good old F9222L IC, replaced it and now the tv works fine bar the backlights are flickering.
    Checking the 24V pin I am getting 21.1v one thing that I have noticed is that two Crapxon caps rated 1500 x 35 are in the board...I thought these were supposed to be 2200 x 35 but cant find a service manual to confirm
    The psu is BN96-03775A
    Thanks for any help
    Re: Samsung LE32R74BDX Backlight flicker
    21.1V will cause flickering -- also check voltage across large 400V cap should have around 390V DC.
    • signup
      • May 2013
      • 189
      381v
        Good.
        Can we have a picture of the power supply?
        Schematic:
        shows them as 1500uF/35V.
        Check if 13V line is bad too.
        Consider CM802 as possible fault.
        • signup
          • May 2013
          • 189
          Cheers Tom
          I should of said I already changed CM802 when I popped the IC in
          The 13v line is down to 11.4v
          Will post pictures shortly
          Could the F9222l be dodgey and breaking down..yet another ebay best buy
            Check RM803 is not open/high resistance.
            Try attaching a 10 ohm, 15W or higher resistor to 13V line. If the line collapses suspect the F9222L, if not, suspect feedback/optocoupler.
            • signup
              • May 2013
              • 189
              RM803 is reading 0.03ohms, I dont have this 10ohm 15w resistor, I have got a few bad psu's especially vestel ones, is there a resistor on their I can use?
                Maplin sell something usable
                10 ohm 10W ceramic e.g.
                http://www.maplin.co.uk/10-watt-wirewound-resistor-2181
                but not for too long (max 30 seconds)
                Just need to see if power supply rails are stable under load or if there is some problem with them.
                • signup
                  • May 2013
                  • 189
                  Which optocoupler will it be and can I test that to rule it out before I go and buy the resistor (I live quite far from maplin)
                    There is a reason I suggested the load test because there is no easy way to test the opto.
                    You may be able to use a car brake light too but you cannot use a car headlamp bulb.
                    • signup
                      • May 2013
                      • 189
                      Hi
                      I have just purchased a 10ohm 11watt resistor, whats the process to check the 13v line, where do I put the resistor
                      Cheers
                        From 13V to ground. This loads 13V with ~1.3A (if at 13V) and ~1.1A (if at 11V.) The rails should stay steady if it is a problem with feedback, or it will drop if it is a problem with F9222L/current limit/bad output cap.
                        • signup
                          • May 2013
                          • 189
                          Do I need to short ps on too..I take it I disconnect the main board and just short 13v
                            Test can be done with main board connected.
                            • signup
                              • May 2013
                              • 189
                              Hi
                              The voltage constantly keeps changing fom 0 upto 17v on the 13v pin
                                What's it do without the resistor?
                                • signup
                                  • May 2013
                                  • 189
                                  What's it do without them?
                                  Without the resistor it is now sat at 20.4v
                                    On the 13V pin??
                                    • signup
                                      • May 2013
                                      • 189
                                      Ooops lets start again, I got solder splatter from a diode to the 24v line Luckily got away without a nice pop and more problems, just dicky readings
                                      I will do the test again and report back
                                        Gotta make sure main board survived 20V on 13V line!!
                                          09-07-2024, 05:50 AM
                                        • C152Heavy
                                          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                          • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                          • Have read ALL applicable threads
                                          • C1818 and CP820 replaced as low hanging fruit
                                          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • fixit007
                                          Samsung flicker - BN44-00932T board or else?
                                          by fixit007
                                          I picked up this TV that the prior owner said - just died.
                                          Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                                          Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                                          Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                                          05-04-2024, 06:14 PM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
                                        • howardc64
                                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                          by howardc64
                                          TV was fixed just after removing Samsung's rear snap cover.
                                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                          Maybe PSU->backlight connector didn't have a good contact?...
                                          07-23-2025, 12:34 AM
