Hi All,
Got this 32" HD LCD tv from ebay a few months ago real cheap, and finally got around to taking a look.
Photos attached showing layout.
Power supply is a Megmeet MIP320FL. No caps appear bulged, but a couple of them test a little high for ESR (tested in-circuit). Caps are a mix of Samxon, CapXon and Aishi.
Video board is labelled ST306TP-T7 - caps are KLA anda gain, none appear bulged.
Symptoms are when the power is turned on at the mains, the red standby light on the front of the TV flashes 4 or 5 times, but no response when the power button is pressed on the side of the TV. Remote doesn't work either.
big connector on the bottom RH side of the power supply has several voltage labels (STB, +5VSB, +5V, +12V) The only one that measures any voltage is the one labelled +5VSB.
Any suggestions on what else I can check before I end up recapped the PSU as a start point?
Photos (best I can do indoors right now) are attached.
Thanks,
Paul.
Thanks,
Paul.
