Sony KDL - 52W4100 powers off after turn on, gives 14 blinks
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Re: Sony KDL - 52W4100 powers off after turn on, gives 14 blinks
    Hello all guys, i am a new member of that beautiful forum, i hope to manage to help you.
    Attached you can find LED error code and description
    • Pragmatiko
      • Jul 2013
      • 468
      • IT
      here instead you can find service manual
      • withalligators
        • Jun 2013
        • 267
        I cut the INV_ERR and BALANCER_ERR wires, connected each to a resistor, and grounded each resistor to the chassis separately. I got the same error. Also on teh same plug are labeled wires BACKLIGHT_ON/OFF, GND, and DIMMER if those are somehow related. As expected the BACKLIGHT is hot until it shuts off. DIMMER, also as expected, seems to correspond with the intensity of the backlight while it's on. There is also a INV_ERR going/coming from each of the power boards that service the inverters (D5 and D4Z).
        • withalligators
          • Jun 2013
          • 267
          Hey, thanks Pragmatiko, unfortunately, that service manual doesn't list the 4100 series in it's coverage. I wish it was just an HDMI error, as that would mean only a main board swap.
            I'm thinking main board fault, then.
            • withalligators
              • Jun 2013
              • 267
              Ha, so Pragmatiko's service manual was inadvertently correct? OK, I'll check out ebay. Unfortunately, the serial number is missing (label was rubbed off) and I know sony can be a real pain with using different parts with the same model. I'll do my best to buy the right board and report back when I get it. Thanks for all the help!
              As an aside, I went to the e-waste bin yesterday, and my heart stopped for a second when I saw a 70" Sharp Elite sitting there. Screen was cracked in the far corner though, and I can't imagine what a replacement panel for that would cost.
                Wow. Amazing, people manage to break even the nicest sets. What e-waste bin was that? Ones here are patrolled by security & CCTV, you can't have anything!
                • withalligators
                  • Jun 2013
                  • 267
                  I don't want to put it out there publicly because the guy on duty lets me take stuff even though I'm not supposed to because he's super libertarian about things. It's in New Jersey in an area where people are pretty wealthy (think The Sopranos), where I'm working for the season. I pick up all the recycling I find in the woods while at work and that's my excuse for swinging by.
                  Last quick question about ordering this board, because I've had bad luck ordering sony boards before. I can find tons of boards that match the model number of the TV that look identical to the one I have. I can also find ones that have the same board and part #s of the one I have, but have an extra plug soldered on that my board doesn't have. Which should I choose. I'm leaning towards the latter ones, but they seem to be *mostly* for the 46" model. What do you think?
                    I'd order only the 52 inch ones, for some reason Sony TVs seem to check the EEPROM on the T-con to verify they are exactly matched.
                    • withalligators
                      • Jun 2013
                      • 267
                      Even though the board number and part numbers are different? Despite looking the same?
                        Hmm, I do not know then. Same LCD panel model? (Good sellers include this.)
                        • withalligators
                          • Jun 2013
                          • 267
                          OK, I got one for 100 with free shipping and a 20% restocking fee if I return. Same Panel. Here's a question I've been wondering. How does an LCD panel go bad? It seems like, shy of cracking, how else can they break? I don't mean the backlight or any of that, just the panel. I'll update when I get the board and install it.
                          Cheers!
                            Generally the drivers on it can go bad, they are attached to the bonds so not replaceable.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I would check out a site like shopjimmy. You can even Email them and ask them.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Possible purchase. Didn't want to start another thread, just a quick question.
                                What do you think that could be here, bad panel?
                                • Junky228
                                  • Jul 2013
                                  Don't hold me to it but i think it's the bulbs failing.
                                    I would say t-con or panel, t-con being very likely. Notice how the bands on the picture don't follow where you'd expect the tabs to be so unlikely to be panel. Probably SONY MOTIONFLOW processor failing on T-con board.
                                    • withalligators
                                      • Jun 2013
                                      • 267
                                      Yoicks, I got home today and threw the new board in there. Same thing. Anything else I should try before I return the BU board?
                                      Cheers
                                        Do you still get voltages on BALANCER ERR or INV ERR?
                                        • withalligators
                                          • Jun 2013
                                          • 267
                                          BALANCER_ERR remains at 0 throughout the whole process. INVERTER_ERR stays at 1.977 while plugged in and drops to .028 once turned on. When it shuts itself off, it spikes to .3/.4 and then works its way down to 0.00. This is with the normal wiring, and not with the resistors in place.
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
                                          • jchon
                                            Sony A1e 5-blinks help
                                            by jchon
                                            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                            I found the service manual, which was critical to know where to probe.
                                            https://www.manualslib.com/manual/20...1e-Series.html
                                            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                            Unfortunately the 5-blinks...
                                            06-28-2023, 11:52 AM
                                          • Abel Bejan
                                            Sony Vaio does not turn on, overheats
                                            by Abel Bejan
                                            I am quite noob in advanced electronics, however I'm trying to fix a Sony Vaio PCG-71211M laptop mainly because I love old hardware. I don't want to send it to a technician because this computer is not important for me, I want to fix it as a hobby.
                                            Shortly, this laptop does not display any video output when turned on, no POST, nothing. The keyboard leds are on and I can actually turn Num Locks on and off. Sometimes the laptop turns itself off straight away, sometimes, mostly after some attempts, the laptops enters a loop in which the cpu fan spins very aggressively and the CPU,...
                                            01-11-2025, 10:11 AM
                                          • Nicktronic
                                            Sony XBR-65X850D 2 Red Blinks
                                            by Nicktronic
                                            I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
                                            Any Sony experts out there that can help??...
                                            11-19-2023, 06:51 AM
                                          • Nicktronic
                                            Sony XR-55X90J 4 blinks
                                            by Nicktronic
                                            Hey guys, got this Sony that turns on momentarily and then goes black with 4 blinks of the standby light. I can't find a service manual, but best guess was the Local Dimming board based on a similar TV saying LD_ERR or BCM_ERR. I found a replacement, but it didn't work. Before I put more money into replacement boards, Im wondering if anybody has seen this issue and what worked for them, or has the service manual for this specific TV.
                                            Thanks!...
                                            02-13-2024, 07:01 PM
