Philips 23PFL5522D/12 PSU problems
  • sparkydz
    • Jun 2013
    • 19
    • France
    Re: Philips 23PFL5522D/12 PSU problems
    Well I've replaced all the caps (Panasonic FM or FR), but PSU still buzzing and cycling. I guess I'll try looking for a problem further upstream. Not easy without a service manual or even a circuit diagram, but I'll have a go and post the results.
    -- Mike
    • sparkydz
      • Jun 2013
      • 19
      • France
      Finally got the set working again, after it sitting in a corner gathering dust. A schottky diode had blown, maybe at the same time as the zener. It was an SB360 and luckily I found a similar one in an old PSU - SB340. I think the 40V should be OK here, but I'll order a couple of SB360 next time I've got a bigger order to do.
      Now to see if I can fix the remote control, although I think the spilt orange juice was probably terminal.
      Thanks for a great site,
      Mike
      • sparkydz
        • Jun 2013
        • 19
        • France
        Update on the remote:
        Seems the orange juice must have eaten away a track _under_ the SMD controller chip, so one row of the keyboard matrix was out - soldered in a bit of very fine transformer wire to replace the track and bingo! Nice to have things working again...
        Mike
        • Ltank
          • Jun 2013
          • 776
          Transformer buzzing can be caused by loose laminations in the transformer or the switching circuit is oscillating at the wrong frequency
          • hermanus
            • Oct 2015
            • spain
            Hi There
            I have the same PSU board,
            Somebody changed the Caps But i think they have thewrong values
            can sombody tell me the listing of the caps because I have the drawing but without the values
            • caspian
              What Zener Diodes on a Linear Power Supply
              by caspian
              Dear members,
              I have a linear variable power supply with unknown brand name that I used for voltage injection.
              Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
              In addition, I discovered that its zener diodes are defective.
              I can replace the burned transistors.
              But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
              Therefore, I cannot replace the zener diodes.
              I do not want to test the zener diodes in a test circuit to discover their model or value.
              no schematics are available...
              05-26-2025, 12:38 PM
            • nev1001
              What zener diode might fix the sound on Maestro Mayhem gaming chair?
              by nev1001
              Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
              The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
              It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
              I think an issue could be a zener diode (or capacitor) which has shorted out.
              The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
              04-17-2025, 05:09 PM
            • G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo
              by G33RT
              Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
              It does power up when pressing the power button.
              I already try the power button while plugin the plug with no result.
              Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
              Could this be an PSU or eMMC issue ?
              07-19-2025, 03:43 AM
            • jean luc ferre
              laptop hp g72 b52sf screen problems
              by jean luc ferre
              on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
              the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
              i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
              i don't understand the reasons of the white stripe at the bottom of the screen below the task...
              06-07-2025, 03:27 PM
              NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
              by sam_sam_sam
              I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
              I bought this from an eBay seller but unfortunately they only had one
              I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
              I bought three of from them to also make battery packs with this output power limit in mind
              I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
              04-23-2025, 05:50 AM
