Panasonic TH50PX60U Power Problem
  • teg33
    • Jun 2013
    • 19
    Re: Panasonic TH50PX60U Power Problem
    I bought/downloaded the full service manual today. I see 2 signals that might be what you are looking for:
    1) There is an F_STB_ON signal that comes from the DG board and goes to P board connector P25 pin 13. That is one of the test points in the "no power troubleshooting chart" that I have looked at before. When the 2 clicks are heard upon applying power, that signal is 2.6V until the 1 click is heard and things go into power save. When no clicks are heard upon applying power there is 0V on this line.
    2) There is an F_STB_15V signal that comes out of the P board connector P10 pins 1-3 and goes to the PA board (to a regulator circuit that generates SUB9V, SUB5V and SUB3.3V). Should there be F_STB_15V voltage when the set is powered up? I left the set on since it's the first time it powered up in 2 days. I checked the voltage here and found 15.7V on pins 1 and 2, but nothing on pin 3. I went to the PA10 connector pins 1-3 which is where this cable runs. Same thing there, 15.7V on pins 1 and 2, but nothing on pin 3. I presume there are 3 wires to handle the current because they all connect once on the board. I checked the TP16 test point on the PA board and voltage is good there. I also checked the SUB9V, SUB5V and SUB3.3V voltages and they are all good. I guess this means the circuit board track is broken open on the P board running up to the P10 connector. Apparently it doesn't matter since there are 2 other wires.
    I was a little surprised the F_STB_15V signal was present when the board was powered up. Should I get the set into a failed mode and check this signal again?
    By the way, the set has been powered on for 90 minutes without issue. This is consistent with earlier behavior, once it's on it is good.
    Thx
      I hope you did not pay too much for the manual, because it is available for free on Elektrotanya.
      http://elektrotanya.com/?q=showresul...oria=&kat2=all
      As for your issue, I am well past knowing where your problem is exactly. But I will say that your intermittent fault is more likely to be on the DG board than the P board. I would suggest that touching up some solder joints on the PSU may be in order, as I recently fixed a 2008 Panasonic with cold solder joints on the PSU.
      • teg33
        • Jun 2013
        • 19
        Paid $13, should have asked first.
        Thanks for all your help, do you mean the P board when you say PSU?
        I am going to order both a DG board and a P board since the various paths through the chart pointed to these 2 boards. I can get them used for a reasonable price with a return policy. I will try the DG first. If it doesn't fix it I will also replace the P board and keep my fingers crossed.
        I think I read somewhere that Panasonic recommended replacing another board (maybe PA??) when replacing the DG board because they were so closely linked and difficult to discern which had failed. Do you know anything about that and whether it's worth doing?
        • teg33
          • Jun 2013
          • 19
          Found the other forum, it says "Panasonic even recommends ordering the PA if you're going to replace the DG "since it may be difficult to determine whether the PA or the DG board is defective.""
          What are your thoughts on this advice? Nothing in the "no power" flowchart ever points to a PA problem so I'm not inclined to replace it.
          Also, let me know what you meant by PSU?
          Thx
            Do you have a PA board? I thought that was dropped on the PX60 and only present on PZ70 1080p.
            • teg33
              • Jun 2013
              • 19
              Yes, I have a PA board. Some of the test signals were on that board.
              • teg33
                • Jun 2013
                • 19
                When you said PSU did you mean the P board?
                  Yep P board = PSU.
                  • teg33
                    • Jun 2013
                    • 19
                    Quick question: Does anyone know how to discharge all the voltages on the P board to make it safe to remove? I see two 18Kohm discharge resistors that look to be in series. Do I just connect ground to some place on these?
                    Any suggestions on where to look for cold solder joints on this board?
                    Thx
                      After leaving the board alone for 30 minutes, take a screwdriver and discharge the capacitors by shorting across them. The energy in the capacitors should be minimal. If you want to do it quicker, a 1K 10W resistor works well.
                      • jtgamble89
                        • Mar 2015
                        • 4
                        I have the exat same tv, when I plug it in it gives the 10 red light blink. only thing is, three relay clicks are heard all together. 1.2.3 there is no space between the second and third click. What doses this mean? what can I do?
                        • JDC
                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                          by JDC
                          ONN 100012588
                          Issue: No Power, Then Rebooting After Main Board Change
                          Short answer: replace main board and power board
                          Technical answer: replace main board and Q306 & Q307 on power board.
                          Long answer:
                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                          07-15-2022, 07:39 AM
                          Tankless hot water heater controller board not powering up when power is applied
                          by sam_sam_sam
                          I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                          I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                          However I would like to know if I could figure what happened to this controller board if possible
                          Tomorrow I will take some better pictures of both side of both boards
                          The...
                          12-09-2022, 09:14 PM
                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                          by sam_sam_sam
                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                          Found shorted diodes on main controller relays there are 3 of them that...
                          01-07-2023, 05:43 PM
                        • Biruslapio
                          Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                          by Biruslapio
                          Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                          It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                          It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                          02-16-2021, 09:44 PM
                        • corrize
                          Nikon D5 – dead, power board issue ?
                          by corrize
                          Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                          When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                          I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                          Now, I try to understand how it works.
                          There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                          04-03-2023, 09:13 AM
