LG 50PG20- No Picture. just humming noise
  • bekweezee
    • Jun 2013
    • 3
    Im very new to electrial type work but Im quick at learning and want to fix this myself.
    I was watching TV today and a "pop" noise happend and the screen went black.
    I did some research and tore the TV apart. A visual inspection of the boards looked good.
    I decided to take the wire harness off of the Y-SUS board and then plug the TV in and turn it on. The humming noise was not present. I plugged the harness tothe Y board back in and then turned the TV on again and the humming was there.
    I got a multimeter and there were 5V going into the y-sus board.
    On the thinner Y-boards on the left, I looked and seem that +5v was supposed to power the 7/8 slot [see picture] but no power was present.
    Is it an accurate assessment to say the problem is in the YSUS board?
    Thank you in advance for your assistance:
  • bekweezee
    • Jun 2013
    • 3
    Re: LG 50PG20- No Picture. just humming noise
    please help
    • capkid
      • Oct 2010
      • 1339
      It sounds like a Y-Sustain problem:
      - Have you closely examined the board for burns or visibly damaged components?
      - Are there any blown fuses on the Y-Sus? Check the fuse(s) on the Z-Sus, also. Fuses are usually marked with an "F" prefix.
      - Is there an LED on the Y-Sus, and is it lit when the TV's turned on?
      I don't know this chassis very well, so I'm unsure of what's under the heat sinks. Can you post a pic or two of the heat sinks from a different angle?
      LG Plasma Mal-Discharge Correction Service
        Also, carefully check the panel for cracks. A loud buzzing can be due to a cracked panel, and the crack can be very small.
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • tracid1987
          Samsung LE40F86BDX (model 2007) noise in picture
          by tracid1987
          Hi
          I have this TV bought back in 2007 and used it for playing on PS3 for 4-5 years actively. After then it was barely used. It was mostly in stand-by mode or plugged out of mains completely for years. Today when i turned it on i have noticed noise in picture on two different locations of the screen. As you can see on the photos (see attachments) the noise is only in a small rectangle area, and if you look at it closely you see that one noise rectangle area is at the upper left corner of first half of screen, the other noise rectangle area is at the upper left corner of the second...
          08-21-2021, 01:48 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • alltvrepairs
          METZ 65MUB8000 picture noise
          by alltvrepairs
          I have this 65 android tv that switches ON ok but after the LOGO is displayed a lot of noise starts appearing across the picture.
          After an overnight OFF it takes a little longer for the fault to appear. I have tried to take advantage of this by heating up the mainboard and TCON while keeping the display cold. But have inconclusive results.
          Tried removing either panel Tabs but with 1 tab only I get no picture. Then I tried the tape method on a small portion of each tab, moving the insulator left to right, but again didn't find any correlation.
          Am...
          11-08-2022, 07:29 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
