LG Plasma TV Vertical color lines, fixable?
  • Sevenqi
    • Jul 2011
    • 292
    This is a LG 50" Plasma TV, model LG0-50PK250, it developed 2 vertical grey/blue lines on the center of the screen weeks ago, now another line on the right side of the two lines.
    These lines are not black, so it seems it's the column driver board issues, but I'm not sure. I attached the photos to show the problem, we can see on the White Wash Mode(third photo), no lines, on the Color Wash mode(Last photo), the white color block will not show lines.
    Any one has the same problem before, is this problem fixable? or just simply replace the middle column drive board (3 of them at the bottom of this set).
    Re: LG Plasma TV Vertical color lines, fixable?
    Not repairable sadly; the panel is bad.
    • ffirmo
      • Aug 2013
      • Portugal
      Hi, when you say panel do you mean the main board?
        No, the actual plasma glass has failed. There are thin driver chips embedded on ribbons attached to the plasma panel. When the driver chips fail, the plasma panel is scrap because you can't replace the ribbons (they're bonded to the glass.)
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • pni
          LG 49uf695v vertical coloured lines
          by pni
          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
          11-14-2025, 03:15 AM
        • viking509
          vizio e65 e3 LED tv color vertical lines center tv only
          by viking509
          I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
          03-21-2023, 12:48 AM
        • afex
          Samsung Plasma TV with vertical lines (model PN50B430P2D)
          by afex
          This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
          This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
          I have attached an image of the TV with these bars displaying....
          11-08-2021, 09:23 PM
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
