sansui lct40sd.
  • willyam1
    • Feb 2012
    • 112
    • israel
    sansui lct40sd.
    hi.
    power led red is on 5v stby ok.
    power it change to green all voltage ok 24v 12v 5v no backlight and after a minute it change to res and right away to green.
    notice that the pin bl on is always o.4v.
    p.s is magmeet mlt198tl.
    main is T.MT8222.1B 9193.
    IN CHANGE A SHOTKY DIODE IN5819 in main this leeds the 5vstby to a regu and more but also lead to the 5v in the p.s very STRANGE.
    wwhen I change the diode the tv works and when I power to stby and operet it again nothing same problem.
    need help.
    thanks willyam
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: sansui lct40sd.
    this diode,is it in the bridge rectifier circuit or an output diode to the secondarys outputs?,if its output diode you need to use UF ONES (ultra fast)
    any pics of this diode?use manage attachments.
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • willyam1
      • Feb 2012
      • 112
      • israel
      Re: sansui lct40sd.
      this diode is sitting in the main board not in the power supply.
      willyam
      • willyam1
        • Feb 2012
        • 112
        • israel
        Re: sansui lct40sd.
        hi.
        problem is the line of 1.2v reg ther is a few ohms in the output rail of this reg.
        it goes to the main ic after pull out all the smd capi.
        nee to change this board hope I will find it .
        thanks to all.
        willyam
        • asr
          Finding replacement diode iPad Pro 3rd gen A1701
          by asr
          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
          07-09-2024, 06:24 PM
        • unimatrix93
          TV backlight zener diode
          by unimatrix93
          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
          The led strips has 9 6V leds.
          02-10-2025, 12:13 PM
        • Baste
          MBR3045CT and SR3045LCT Schottky diode testing help.
          by Baste
          Hello experts,
          Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
          Aneng ST182 Meter.
          Diode mode.
          MBR3045CT:
          Diode mode
          Pin 2-1 - 0.150v
          Pin 2-3 - 0.150v ...
          10-21-2025, 06:14 AM
        • NicRac
          monowheel repair,Is the diode the problem?
          by NicRac
          Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
          First of all, I am new here. Therefore I will shortly introduce myself.
          I am Nico and currently I study Physics.
          In my freetime I like to build and repair stuff. Especially big battery's.
          A few years ago I got myself an electric unicycle, monowheel or however you call that.
          The battery bms was broken so I replaced and resolder that. Nothing big.
          I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
          07-26-2024, 06:13 AM
        • dennis_elx33
          NO BODY MARKING Diode
          by dennis_elx33
          Hello Everyone,
          I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
          While compared to the reading of another diode from the next channel it won't read at reverse bias.
          Now the problem is; it does not have any body marking.
          So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
          What do you think is this diode?
          Can you please suggest what part number can i use to replace this faulty diode instead?
          Hoping that you...
          06-14-2024, 12:36 AM
