CRT TV, Telesensory Rainbow....Dead!!
  • Andyd1970
    • Feb 2013
    • 374
    • united kingdom
    Hi Guys,
    I have been asked by a local care home to repair a Telesensory unit, it is used by a mentally ill blind resident of there care home.
    I said no problem to help out but I cant find the cause yet. Basically the unit is dead, I am getting power to the light below the CRT that is used to illuminate the newspaper/document.
    So thought I would ask you guys to see if anyone can help me with some fault finding on a CRT.
    kind regards
    Andy
    Re: CRT TV, Telesensory Rainbow....Dead!!
    My guess would be these are two power supplies one for the fluorescent lamps and one for the CRT monitor. The left one is for the bulb, right is for the monitor.
    https://www.badcaps.net/forum/attach...0&d=1370446733
    The CRT looks like it only has a single voltage requirement so check if that is present, see if the rating is labelled. But possibly around 100~150V DC if it is straight B+ for CRT... Could also be a 12V or 24V monitor.
    For a device which people depend on this is quite poorly made, I am very disappointed! Seriously, these units are not cheap, so you would expect they would put better components into them, and better care into assembling them.
    • Andyd1970
      • Feb 2013
      • 374
      • united kingdom
      Hi, On the last picture you will see a black/red pair that goes to a PCB on the side of the unit. I unplugged that cleaned contacts and refitted it and hey presto it worked!! It worked for a good few days swtiching it on and off, until today I switched it as I was going to return it I heard the sound of the screen energising but no picture. so I switched it off and tried again later and now no sound as the screen energisies. The lights operate that are used to illuminate the newpaper etc.
      Suggestions? Tom made reference to some things but sure where they are likely to be to check.
      Andy
      • Elysarian
        • Mar 2013
        • 200
        • United Kingdom
        The sound as you switch on is likely the degaussing circuit operating (this is usually controlled by a PTC device in series so it only operates for a split second at switch-on from cold).
        What this means is that the CRT's board is getting power - can't see what's under there but my initial investigation would be centered around the line output transistor and associated circuitry (these often fail short and cause a cascade failure in the SMPS or, if you're lucky, fail open and replacement will fix the fault).
        You should also check for dry joints around the line output (flyback) transformer if the fault is intermittent as quite a number of the necessary voltages inside a TV are generated from that.
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          did anybody notice this choke is burnt?
          could you take pics of the bottom of the board
          Follow the white rabbit.
            Is it? Just looks like varnish to me.
            • R_J
              • 9553
              I would check for poor solder connections near the plug you cleaned, I don't think cleaning it did anything but removing and reinstalling the plug possibly caused the bad connection to work for a bit.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Either way, are those Elna audio capacitors in an smps?! The two just under that inductor.
                Muh-soggy-knee
                  ...Elna make a LOT more than audio capacitors. They also make low ESR capacitors suitable for SMPS.
                  • Andyd1970
                    • Feb 2013
                    • 374
                    • united kingdom
                    Hi Guys,
                    Thank you for all the input, so far I have checked for dry joints on the PSU, I have reflowed the 12v pins on the PCB that the PSU feeds that is located on the side of the unit. See pics of the two PCB's.
                    I checked that the PSU was outputting 12v to the side PCB and it is. The light system works but I guess thst is driven by the other PSU.
                    Andy
                    • Andyd1970
                      • Feb 2013
                      • 374
                      • united kingdom
                      Hi Guys,
                      I reflowed all the points on the PSU and the connector on the side PCB where the 12v goes in, still dead but I do get the screen degausing when I switch it on after it has been of for a while.
                        The CRT takes 12V? So do you have 12V when it powers up?
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          We are looking in the wrong spot. You can see in the first picture, white and black wires (neutral and line) going to the crt board. That is the board we need to look at.
                          Look on that board for burn marks, bad solder joints, or blown fuses. Test all fuses. Could you take some good pictures of that board, bottom side and a few different angles of the top side, please?
                          Also, have you tried un-plugging the 12v cable from the power supply, then plug it back in? Could be a bad connection on the connector contacts.
                          Muh-soggy-knee
                          • Andyd1970
                            • Feb 2013
                            • 374
                            • united kingdom
                            Hi Tom,
                            I say 12v as the right hand PSU outputs 12v at switch on and the PCB to the side it feeds (see pictures) has 12v written on the PCB. I can hear a sort of low sound like a creaking sound from the rear of the monitor/PCB below it.
                            • Andyd1970
                              • Feb 2013
                              • 374
                              • united kingdom
                              Hi All,
                              Sorry to be a pain, but the care home are desperate for this back and cant afford a new one as they are soooo expensive. I have tried a few things but due to the voltages on the PCB I am not confident where to start, if it was an LCD I would be much happier due to Tom66's excellent advice.
                              Andy
                                May I suggest you offer an alternative?
                                A Raspberry Pi computer (£30), plus webcam (£10) plus HDMI/DVI LCD monitor (£60) can do the job of this device for around £100.
                                Repairing it may be very difficult, I have no CRT experience, and without schematics, it may be nigh impossible.
                                • goontron
                                  5000!
                                  • Dec 2011
                                  • 4108
                                  • US
                                  you say raspberry PI, oh no here come the linux devs since you need to be one to get that thing setup
                                  • Andyd1970
                                    • Feb 2013
                                    • 374
                                    • united kingdom
                                    Hi, Goontron,
                                    I saw you mnetioned about the choke which to me looks OK, I did take some pictures as per your request, do you have any thoughts. I apriciate TOM66's suggestion, but the thing is the guy has used this for years and only wants this back. So I am trying to do all I can to help.
                                    Andy
                                      No, you do not. I have set one up and it is easy as pie, seriously, blow an image to an SD card, launch video cam app, connect camera & you are done.
                                      • goontron
                                        5000!
                                        • Dec 2011
                                        • 4108
                                        • US
                                        really? i had one when the project first started and it was CLI. its GUI now?
                                        • ngml
                                          Repair of an LG split AC system indoor unit PCB
                                          by ngml
                                          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                          This indicates an error in the communication between the outdoor and the indoor unit.
                                          The outdoor unit is fine, so the problem is the indoor PCB.
                                          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                          Does anybody have the schematics of this board,...
                                          02-01-2025, 12:55 PM
                                        • nobbnobb1
                                          Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                                          by nobbnobb1
                                          Hi guys,
                                          Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                                          When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                                          02-03-2022, 11:14 AM
                                        • Gjackson
                                          Air-conditioning unit power supply failing to power up
                                          by Gjackson
                                          Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                                          01-08-2022, 09:24 AM
                                        • navagator
                                          Hitachi Power Supply Unit Interchangeability
                                          by navagator
                                          I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
                                          Does anyone know if these 2 power supply boards are interchangeable?
                                          Thanks.
                                          01-08-2024, 07:53 PM
                                        • valvashon
                                          Repair Success! Middle Atlantic UPS2200R-IP
                                          by valvashon
                                          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                          02-06-2024, 12:54 PM
