Testing this buffer board
  • signup
    • May 2013
    • 189
    Hi
    I have got a plasma that has blown 4 fets on the Y sus (Pictured) everything else seems ok.
    Its the buffer that is worrying me, normally you can see pit marks in the IC's and know if they are blown, how do you check the ones pictured, or do you advise just changing the buffer board
    Thanks in advance
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Testing this buffer board
    Originally posted by signup
    Hi
    Thanks in advance
    I'm assuming 'the buffer' is the y-buffer?
    How did the MOSFETs blow? Short circuit gate-drain?
    My guess is, yes, the buffer boards should be replaced. Chips can short circuit without melting or burning. But yeah, I'm no expert...
    Another user on here, tom66, knows a lot about plasma displays, he will be able to help you for sure
    -Ben
    Muh-soggy-knee
    • signup
      • May 2013
      • 189
      Yes your assumption is correct, this is the y buffer, the mosfets were S/C'd
      Is it always the case when the fets blow it takes out the IC's on the buffer, and what will happen if I put a new Ysus in and the board is blown will it take out the new y sus board??
      Thanks again
      • martyparish
        • Dec 2012
        • 313
        I believe you just need to find the ground pin on each of the ribbon connectors and then take your meter and run it slowly down each side of the connector to check for shorts. Check Tom66's messages, somewhere he posted a video on it.
        • martyparish
          • Dec 2012
          • 313
          Here's that vid:
          http://www.youtube.com/watch?v=51SZsfH60EY
          • signup
            • May 2013
            • 189
            Thank you so much will have a go now
            Is that your own video Tom?
            • signup
              • May 2013
              • 189
              Just one question,
              It says I need to find the sustain output on the buffer board
              The only connection plug I have is labelled
              1. GND
              2. 5v
              3. GND
              4. OC1
              5. OC2
              6. Data
              7. LE
              8. GND
              9. CLK
              10. GND
              Which pin am I aiming for
              • martyparish
                • Dec 2012
                • 313
                I'm pretty sure you want to use ground. Here's another pretty good demonstration:
                http://www.youtube.com/watch?v=5hVi5gd0aec
                  Yes, my video.
                  The buffer chips are under the heatsinks.
                  • signup
                    • May 2013
                    • 189
                    Cheers Tom, got the IC's just wanted to know which pin out I needed to use, the buffer has got no continuity through any of the flat cable connections.
                    Tom Thank you it must be a first that I have seen a proper tutorial that explains more in laymans terms, will have a look through a few of your others later..Brilliant
                    Can I just ask a stupid question whilst your here, I couldnt be arsed to go and get a new battery for my DMM so I used my AMM for the continuity checks, when I tested it showed continuity through every single terminal on each of the connectors...Why?
                    I was forced to get a new battery and no shorts anywhere
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • howardc64
                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                      by howardc64
                      • Prior owner tried a replacement main board. No difference.
                      • Samsung 2x red blinking standby LED = panel fault
                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                      07-19-2025, 10:54 PM
                    • repair-it
                      Need advice testing a samsung power supply board with scope
                      by repair-it
                      I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                      07-12-2025, 11:00 AM
