LG 42PC3D-UD dead no-lead solder arrggg!
  • xaxxon
    • Jul 2010
    • 17
    this 42" has a hybrid i.c. on the y-sustain board that i'm trying to desolder. unfortunately LG used no-lead solder on it. this stuff seems nearly impossible to remove.
    does anybody have any tips for dealing with this stuff?
    i got a tip on another site where you pre-treat solder wick with solder paste, which helped, but only somewhat.
    i've got a 35 watt iron, solder wick, paste and a solder sucker to use.
    Re: LG 42PC3D-UD dead no-lead solder arrggg!
    You will need an iron closer to 60W and with temperature regulation. These things are nasty to get off!
    • capkid
      • Oct 2010
      • 1339
      I've been through this frustration, and I only use a desoldering gun now. You can try adding a little solder to each pin so that the solder flows better when you try to suck it up. The heat sinks on the IPMs absorb a lot of the soldering iron's heat, so a higher wattage iron would be best. Also, a hair dryer or a heat gun on a low setting would be helpful.
      LG Plasma Mal-Discharge Correction Service
      • flocko
        • Nov 2012
        • 1121
        • uk
        I have found that if you first with a pair of pliers snap off the ends of the set screws, then drill them out to remove the heatsink, you can cut the leg's off the IPM and desolder them one by one no need for lots of heat. when you fit the new IPM use nut's and bolts
        • xaxxon
          • Jul 2010
          • 17
          thanks for the replies.
          flocko: that sounds crazy enough to work!
          • flocko
            • Nov 2012
            • 1121
            • uk
            just read my post again i did not mean fit IPM with nuts and bolts just the heatsink ?It's just a way to get the heatsink off leaving just the IPM on the board and making a hard job easy without doing damage
              Put the screws in from the top instead of the bottom to make it easier?
              • ktmmotocross
                recommend good solder wick on aliexpress
                by ktmmotocross
                I get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
                02-08-2024, 12:48 AM
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • corrize
                Best way to solder LVDS connector for beginner (and qfn) ?
                by corrize
                Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                See the test :
                https://youtu.be/bNAzC-EvqHs?t=1767
                With hot air from bellow the board, that's...
                03-09-2023, 02:57 AM
              • double_DD
                How can I be sure that my EC chip is dead?
                by double_DD
                As the title suggests, how can I be sure that my EC chip is really dead?
                I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                03-12-2025, 07:47 AM
              • petemanuk
                BGA solder balls not connecting - help pls
                by petemanuk
                So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                11-16-2022, 05:21 AM
