lg19lu4010
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    lg19lu4010
    looking for sch for this tv,more so the sch for the psu AIP-0187A (LIEN CHANG)
    TV MODEL NUMBER LG19LU4010
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
  • diamon
    Changing model number 5500 to 5510
    by diamon
    I would like to place a Dell Latitude 5500 (black color) motherboard into a Dell Latitude 5510 (silver color) chassis .
    How can I change the model number of this laptop?.
    When you're entering the bios (F12), you see in the left corner Latitude 5500, I would like to have this changed into Latitude 5510
    I have already edited the 5500 bios bin file with HxD, and changed the 5500 into 5510, but after re-flashing and soldering the chip back, the name in the left corner is still Dell Latitude 5510 (have entered the ServiceTag of the 5510 chassis).
    Have uploaded the original...
    06-19-2025, 03:25 PM
  • piernov
    Beginner's guidelines
    by piernov
    You have a laptop that does not power on, powers on but shows no image, crashes, etc… You want to fix it but you don't know where to start.
    There are 2 situations:
    1. You just want your laptop fixed
    2. You want to learn about fixing laptops
    Sorry, but if you're in situation number 1, we recommend you to use the services of a trustworthy professional repair shop.
    Unfortunately, if you're not serious about learning, you will waste your time and money, and you will make us waste our time as well.
    If you are in situation number 2, then please continue and...
    09-20-2020, 09:46 AM
    Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
    This is a new item at Electronic GoldMine that has arrived within the last few weeks
    Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
    Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
    https://theelectronicgoldmine.com/products/g28392
    One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
    11-24-2024, 01:25 AM
  • sikocan
    Lenovo X1 Carbon 9th Gen Black Screen
    by sikocan
    I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
    SN: PF3G1REP
    MODEL: 20KW-00J1AU
    PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
    Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
    06-24-2025, 09:01 PM
  • Valtekken
    Lenovo IdeaPad 3 15ADA05 (model name 81W1) - Trying to flash the correct serial number, machine type and UUID without success
    by Valtekken
    Specs:
    • CPU=AMD Ryzen 5 3500U
    • GPU=(integrated) Radeon Vega Mobile
    • RAM=8GB (2x4GB, a 4GB set is soldered), DDR4; 1x4GB Ramaxel, 2400MT/s, RMSA3310MJ86H9F-3200; 1x4GB Micron, 2400 MT/s, no part number (soldered)
    • Storage=512GB, NVMe SSD, hfm512gdhtni-87a0b
    Hello everyone.
    My issue isn't massive, but I'd like to get this solved since I'm trying to fix a friend's laptop.
    A botched BIOS update by Lenovo bricked this laptop, so I used my BIOS programmer to reflash the BIOS on it and saved it from an early demise. All is good now, but the BIOS reports the S/N, MTM and UUID...
    09-10-2025, 04:14 PM
