I have Vizeo LCD model VX37L HDTV. Problem is Tv turn off after showing blue screen and no input signal.I can turn on again but tv keep turn off.
Check DU4 ( instead of U4) on main ,AMC1117 dead (pin2 output 0v ,pin3 3.3v, pin1 0v). I replace with another ADJ AMC1117.Tv shows same problem.
but DU4 has pin2 1.25v pin3 3.3v pin1 ov. I check r2=0 ohm r1=83 ohm.I do not know why r2 is 0 ohm. Is this shorted because of previous ic damage?
I also want to know the good voltage of DU4 output.
