Problem with Vizio LCD VX37L HDTV
+ More Options
Posts
  • hienton2
    • Sep 2009
    • 183
    I have Vizeo LCD model VX37L HDTV. Problem is Tv turn off after showing blue screen and no input signal.I can turn on again but tv keep turn off.
    Check DU4 ( instead of U4) on main ,AMC1117 dead (pin2 output 0v ,pin3 3.3v, pin1 0v). I replace with another ADJ AMC1117.Tv shows same problem.
    but DU4 has pin2 1.25v pin3 3.3v pin1 ov. I check r2=0 ohm r1=83 ohm.I do not know why r2 is 0 ohm. Is this shorted because of previous ic damage?
    I also want to know the good voltage of DU4 output.
    Re: Problem with Vizio LCD VX37L HDTV
    When it turns off, does VIZIO logo go from white back to orange?
    • hienton2
      • Sep 2009
      • 183
      Hi Tom
      Yes Logo turn to orange when it turn off.
        "Problem is Tv turn off after showing blue screen and no input signal" how long does it stay on? TV will go into standby if it does not receive signals. Can you feed video signals to the TV?
        • hienton2
          • Sep 2009
          • 183
          Hello Budm.
          Take about 6 seconds to turn off. During the time it is on It does not shows Menu or any OSD only no input. I want to know the voltage out of DU4.
          The LDO 1117 some label U some label DU. I see about 5 DU and about 5 U.
          No schematic.
          • hienton2
            • Sep 2009
            • 183
            After insert input . Tv is now ok.When I had tv I insert antenna It shutdown after 6 seconds.I do not know whether new 1117 or no input shutdown.
            Thanks Budm
              This is a feature of some older Vizios. I saw thesame conclusion on 42" and 50" Vizio plasma too. It appears to trip some people up. Usually No Signal appears at least...
              • hienton2
                • Sep 2009
                • 183
                The tv has examined by some one. He said main board needs replaced. owner brought to me. I am confused Tom
                  I'm guessing they never checked it with an input.
                  • hienton2
                    • Sep 2009
                    • 183
                    Do you believe it? Now I remove all input It stay with blue screen no sign of "no input" on screen.I already unplug AC.
                      OK, I'm not seeing a problem here. It's just giving you more time if you unplug it while it is running.
                      • hienton2
                        • Sep 2009
                        • 183
                        OK Tom. I will unplug it and let you know.
                        • hienton2
                          • Sep 2009
                          • 183
                          No different , TV works ok. With hdmi and avi.
                            And the fault is??
                            • cashkennedy
                              • Aug 2011
                              • 666
                              Originally the TV would turn off after 6 seconds.
                              Now with a input connected it stays on and displays the input correctly
                              It is working , there is no problem?
                              Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                              • hienton2
                                • Sep 2009
                                • 183
                                At the beginning
                                I did not connect avi or hdmi but I did connect air antenna.TV shutdown after 6 seconds. Tv did not response to input button.
                                  And you now have confused two people, because neither us know if the TV is actually working for you or if you are complaining about a fault. Please clear this up.
                                  • hienton2
                                    • Sep 2009
                                    • 183
                                    Hi Tom.
                                    I am happy to have help from Supper techs here.
                                    All I did I already showed every post from the first one.I am confused too.I can not find out the cause. In experience sometimes we remove and install board
                                    then tv fixed without doing anything. But this one I did not remove the main board.
                                    TV is OK now.
                                    • cashkennedy
                                      • Aug 2011
                                      • 666
                                      And now in the end TV works good for antenna, hdmi , and avi?
                                      Congratulations, enjoy!
                                      From what I can tell it was just the 6 seconds with no input causing it to shut off. It would not switch inputs maybe because it was shutting off to fast / or it didn't sense the antenna input?
                                      • tieny
                                        • Feb 2012
                                        • 478
                                        I had a 37" Vizio with a similar problem. Turned out to be the main board at fault. There will be a delay when the Tv is turned on before you can access the OSD menu or change the input. After replacing the main board the delay problem was fixed.
                                        Usually with the RGB input itll shut off if there is no input. So if it shuts off and turned back on with no inputs there will be a delay that will prevent you from accessing or changing the input and itll shut off once again and youll be stuck in this loop.
                                        • rajbot
                                          No Power problem with Vizio E60-E3
                                          by rajbot
                                          Hi all:
                                          I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
                                          I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
                                          On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
                                          03-22-2023, 08:09 AM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • Pinky Deepak
                                          Vizio M60-C3 Left Edge problem
                                          by Pinky Deepak
                                          I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
                                          Here's a video of both the issues: https://youtu.be/hMqc760nB3o
                                          09-27-2024, 05:11 PM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
