Panasonic TH-42PZ85U (2) 1"1/4 inch vertical line down middle of screen
    Re: Panasonic TH-42PZ85U (2) 1"1/4 inch vertical line down middle of screen
    By the way all just for your information i successfully fixed my Plasma TH-42PV8H which was giving me 13 Red blink error code.
    I baked the A-Board in the Oven for 10 Mins at 230 Celsius which re-flowed the solder at bad joints, however i melted the plastic inside the AV/Component and Composite ports. Since the melted plastic completely covered the holes inside the ports hence i had to carefully drill holes back inside them which worked and the TV was receiving the signals.
    Those who are planning to bake their A-Board for reflowing please set the temperature at 214 Celsius and not more then 5 minutes to prevent melting. Or else if you plan to bake for 10 mins please cover the ports with some aluminium foil to avoid melting.
    Thanks.
      Been there done that. Lol
        Well the fix of baking A board was short lived, today again my plasma started giving 13 Red blink. I am thinking of replacing IC8001 now.
          Have you tried applying heat to the offending IC to see if you bypass the 13 blink code
            I don't have a heat torch so I again tried to bake it today hoping it would fixed it but this time it comes up with 3 Red blinks. Also earlier I used to notice slight glow on the plasma screen while turning on and then there was no OSD and followed by 13 Red light blinks, but this time when I turn on the TV the screen did not glow and I got 3 red blinks. Any idea how to fix it??
