Vizio E420VT resets itself at certain times
  • baitism
    • Apr 2013
    • 43
    I purchased one of these for $50 on craigslist. The picture is awesome and as long as I don't alter the default tv settings, it seems to work fine with my computer. However, the second I try to change settings or attempt to control it with the remote, it shuts off most of the time, but not all.
    I saw posts online talking about it being a firmware flaw, but nobody really had a solution. I just wanted to post it on here and see if anyone had any ideas. I already took off the back and didn't see anything (capacitors, connectors, etc) that looked out of sorts. Seller said the tv was 18 months old.
    Video: http://youtu.be/x8a64zCo04w
    Let me know if you have any ideas. Thanks.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Vizio E420VT resets itself at certain times
    Is is me or are some of the little capacitors on the psu bulged?
    Muh-soggy-knee
    • baitism
      • Apr 2013
      • 43
      It is possible. I am going to test all the capacitors when I get off work today.
      • baitism
        • Apr 2013
        • 43
        Being fairly new to this stuff, will the capacitance readings change as the capacitors lose power? Also, is there a good place to find info on the capacitors on the board? It seems the specs are on the side facing the board on most of these and I cannot ready them.
          You should not test capacitors while they are energised.
          • baitism
            • Apr 2013
            • 43
            I figured as much. The board is disconnected and I am running through the readings. If I get repeated overload readings on a particular capacitor, am I testing it wrongly or could it be bad.
              Are you just measuring capacitance? Or ESR?
              • baitism
                • Apr 2013
                • 43
                Capacitance, but looking online, it seems I need an ESR reader. Do you have one you specifically recommend? Also, how interchangeable are the video boards for Vizio (or any brand for that matter). Would another video board from a 42" Vizio work? I ask this because it is possible that the tv is suffering from a hardware fault that was corrected in later models.
                  I would be surprised if your problem is related to the capacitors. Nowadays it is a rare occurrence. I use a Peak Elec ESR60, which costs around $110. You can get ones for as little as $40.
                  • aaronwt6
                    • Apr 2013
                    • 855
                    • US
                    Based on what I just went through with a E470VA with a very similar control board, I'm going to say replace the main. I tried the eeprom first with no luck. Then got a control board and that also didn't work. Make sure the numbers match exactly. I got it right on the third try and the TV works perfect now. Specifically the numbers under the model board assembly. That's what finally got me the correct one.
                    I just realized I may have one of these at home. I'm leaving at lunch and will check the board out. Post a nice clear picture of the white sticker on yours so we can compare numbers.
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      I picked up an ESR meter via eBay for $20 shipped. It has no case, but it does the job...I think, I haven't actually identified a bad, non bulged, cap with it yet.
                      • baitism
                        • Apr 2013
                        • 43
                        Thanks for the heads up Aaron. Here are the pictures.
                        • aaronwt6
                          • Apr 2013
                          • 855
                          • US
                          Sorry man. Forgot to check this til today. It's a SV420M so not gonna cut it.
                          Like I said, changing the main on the 47" I have here did the trick though. Let us know how you make out on it.
                          • aaronwt6
                            • Apr 2013
                            • 855
                            • US
                            What I found when doing mine was the number right below the board model assembly had to match exactly. The one on yours that starts with 705. Seemed that this TV had several different build configurations.
                            • baitism
                              • Apr 2013
                              • 43
                              Thanks Aaron. I found many boards that match on Ebay. My only question is some of them are pulled from the 32" model of the tv. Does that even matter or am I strictly trying to match the board numbers?
                                It may matter if the 42" are 120Hz and the 32" are a "mere" 60Hz.
                                • baitism
                                  • Apr 2013
                                  • 43
                                  Both are 60hz.
                                    Are both 720p, or 1080p?
                                    • baitism
                                      • Apr 2013
                                      • 43
                                      E370: 1920x1080
                                      E420: 1920x1280
                                      However, most of the sites listed show the E420 at 1920x1080 so maybe you could shed some light on if their is any difference. The part numbers and boards are identical.
                                        I can guarantee you there is no such thing as a 1920x1280 panel. That is most likely a typo and should be 1920x1080.
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • Msb1xr
                                          Have to turn on 77” LG C1 multiple times to get to come on
                                          by Msb1xr
                                          Have to turn C1 on and off multiple times for it to fully come on
                                          Have to run LG C1 on multiple times for it to fully work
                                          If I have it off for a while I have to turn the TV on and off and handful of times for it actually display what it's suppose. The times it doesn't nothing comes up like the input or dobly vision logo. Once it's on I can turn it off and back on fine and the picture looks perfect.
                                          Unhooked everything except antenna. Reset tv to factory settings. Let it sit and when I tried 2hrs later turned TV on and sound comes through but no picture....
                                          10-13-2023, 04:09 PM
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          08-24-2025, 03:47 AM
