Samsung LE40B530P7 White out
  • suffolkchat
    • May 2011
    • 11
    Hi all
    Help needed, LCD fires up just about and see the picture but with a white out
    all colours near max strange
    All caps look fine
    i've looked at few posts, and possible can rule out the psu? below causing it
    I have tried info menu mute power reset with no change
    And more so looking at this maybe the problem ?
    its well tucked away so not had a good look
    any advise
    many thanks
    john
    Re: Samsung LE40B530P7 White out
    Is there an AS15 IC on the T-con? (Small square chip.)
    • suffolkchat
      • May 2011
      • 11
      No nothing ic of that id
        We need a closer image of the T-con board, ideally we would be able to read the part numbers on each IC, if necessary, split the photo into two or four parts.
        • suffolkchat
          • May 2011
          • 11
          ok will take original pic now
          • suffolkchat
            • May 2011
            • 11
            Picture of board taken out
            thanks
              Does your screen look like this?
              https://www.badcaps.net/forum/showth...264#post328264
              Or like this:
              https://www.badcaps.net/forum/showth...mma#post304275
                You can try testing the voltages in the box marked GAMMA. Each voltage 1 thru 18 should test slightly higher than the last.
                • suffolkchat
                  • May 2011
                  • 11
                  no its not
                  when turned on
                  i get full bright white screen with a faint shaeded picture with hardly any colour
                  as if colours were nearly off but brightness is full up
                  yet colour controls are up high
                  • suffolkchat
                    • May 2011
                    • 11
                    i just found meter batts dead so i cannot test voltages tonight
                      It does sound like GAMMA fault, so please perform the test I suggested (board installed in TV.) Gamma circuit is used to drive the panel brightness, making the light output linear with the input signal.
                      • suffolkchat
                        • May 2011
                        • 11
                        ok i will test
                        thanks
                        • suffolkchat
                          • May 2011
                          • 11
                          Just out of interest the back light is fine
                          powered by psu board yes ?
                          john
                            Yes
                            • suffolkchat
                              • May 2011
                              • 11
                              Hi i did try doing the gamma test but my hands were not stable enough
                              i since bough s/h tcon and although diferent patern of colours its basically the same problem still
                              i will post oic of picture white with hint of colour and program
                              • leonard
                                Leonard085
                                • Aug 2010
                                • 10
                                • Ireland
                                more than likely the t-con board or the lcd panel itself
                                here is a link on how to test the psu
                                https://www.youtube.com/watch?v=wrD1d-a2fnA
                                  09-07-2024, 05:50 AM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
                                • tech9pc
                                  Samsung QN65Q80AAFXZC QLED TV has a white vertical Bar
                                  by tech9pc
                                  Hi all Happy Holidays! Was just wondering if you think this white vertical bar would be fixable. Maybe bad TCon or ribbon cable? Contemplating trading a 50 inch Hisense 4K Roku for the Samsung but might get burned lol. The Samsung is model QN65Q80AAFXZC QLED TV has a white vertical Bar. Any thought appreciated. Thanks.
                                  12-24-2023, 11:28 AM
