sharp lc32l400m
  • willyam1
    • Feb 2012
    • 112
    • israel
    sharp lc32l400m
    hi to all.
    problem is pic ok but no sound in all inputs.
    when I touch my finger in the smd amp ic I can hear some noise in the speakers.
    I try also all the menu reset and also the factory reset no joy.am I missing something in the reset procces or I just have to order a new main board its seems .
    that it cant be repair (the main board).anyone hade the same problem?.
    thanks willyam
    Re: sharp lc32l400m
    What equipment do you have - oscilloscope?
      Re: sharp lc32l400m
      Does it have Audio line level OUTPUT Red and White RCA jacks? If it does, try using that outputs to feed powered speakers such as PC speakers system to see if you get the sound from those two RCA jacks OK.
      • willyam1
        • Feb 2012
        • 112
        • israel
        Re: sharp lc32l400m
        Thanks tom66 and budm yes i got osci.
        But its seems to me that the problem is in the main ic wiyh big cooling.
        Ther is no way to get to that ic.
        I will check about what budm suggestion.
        Willyam1
          Re: sharp lc32l400m
          Well, once you try budm's suggestion, you can look up the datasheet of each chip in the audio chain and test the output with a scope, and see if one chip somewhere is malfunctioning.
          • sheffieldyorky
            ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
            by sheffieldyorky
            Hey there people
            While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
            This is what I tried, but not in any order.
            Google
            YouTube
            BIOS
            Command Prompt (administrator privileges)
            On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
            10-25-2025, 02:22 AM
          • Mitike
            SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
            by Mitike
            Hello guys,
            I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
            According to other sharp SM-s it is lamp error (I can't find SM for this model)
            And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
            If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
            02-16-2020, 08:11 PM
          • odie34
            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
            by odie34
            I am a hobbyist (not a professional) so please be gentle...
            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
            02-18-2024, 09:11 AM
          • ictc
            Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
            by ictc
            I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
            Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
            The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
            02-25-2025, 12:15 PM
          • kotel studios
            ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
            by kotel studios
            Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
            Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
            I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
            12-14-2024, 10:48 AM
