Hisense Plasma PDP4235EU
  • s_henya
    • Jan 2011
    • 483
    • Israel
    Re: Hisense Plasma PDP4235EU
    Im trying to take the Y Buffer board out, but the ribbon cables dosn't come out,
    i opened the latch who secure the ribbon cable, and tried to pulled it out,
    i don't want to put any power to the cable, im afraid to break it
    am i doing something wrong?
    by the way Tom66 the problem got worst,
    it happens all the time without starting time issue.
      Lift the latch, push very gently downwards and it should slide out. Those cables are bonded to the panel, so you're right to be careful, as they cannot be replaced if they break.
      • s_henya
        • Jan 2011
        • 483
        • Israel
        ok got it out!
        tried to reseat the flat cables with no luck,
        couldn't find a replacement Y buffer board.
        model :42F1_YDRV
        so i guess i will have to order a single chip and do that nasty work of soldering that chip back
        i saw on Youtube that in order to check a chip, look for shorts between the power and ground.
        http://www.youtube.com/watch?v=WB238KaaHVA
        anyone tried this method, know if its any good?
          Do you have no picture at all or is the top 1/3rd black permanently?
          • s_henya
            • Jan 2011
            • 483
            • Israel
            1/3rd top is black permanently,
              OK, then the buffer is not shorted. Replacing just that second IC should be all that is necessary.
              • s_henya
                • Jan 2011
                • 483
                • Israel
                #27
                ok tom,
                i will open an account on aliexpress and order that chip.
                hope to update with good news.
                thank you very much for now :-)
                  Have a look around on several different sites first and check if it's available elsewhere for less.
                  • s_henya
                    • Jan 2011
                    • 483
                    • Israel
                    #29
                    couldnt find this chip on ebay, and i don't really know any other electronics online stores,
                    i know it's not cheap but i got it for 11 dollars including shipping to israel.
                    i hope it will solve the problem, and even if it won't, its still worth the risk.
                    • willyam1
                      • Feb 2012
                      • 112
                      • israel
                      #30
                      s-henya hi.
                      I hade the same problem and I fix it.
                      you need the original remote and reset procces is needed.
                      menu -audio- balance-0532 -factory int-protectly .
                      end of story .
                      willyam
                        Are you sure? I have never heard of a main board causing the part of the panel that should be glowing even with no signal to go out completely.
                        • s_henya
                          • Jan 2011
                          • 483
                          • Israel
                          #32
                          hey william,
                          i've tried factory setting reset, it worked when i just got it,
                          (the problem was happening randomly)
                          (so i think it was just luck)
                          but over time it became permanent.
                          and the reset doesn't fix it.
                          • willyam1
                            • Feb 2012
                            • 112
                            • israel
                            #33
                            hi.
                            my problem was that the pic become smaller in the 1/3 off the screen (up to down) and after a wile become smaller from left to right.
                            so I make the reset process and its works costumer happy.
                            do you make the reset ok?.
                            WILLYAM
                            • s_henya
                              • Jan 2011
                              • 483
                              • Israel
                              #34
                              its not shrinked the upper side is totally
                              cut off.
                              i did the reset through the menu
                              didnt work the last time
                              • tomketcz
                                schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
                                by tomketcz
                                Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
                                10-01-2025, 03:13 AM
                              • Coolgoodman
                                Faulty Hisense 85Q6NAU TV
                                by Coolgoodman
                                85” Hisense TV
                                Greetings,
                                Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                                Dear TV technicians of forum, I hope this message finds you well.
                                I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                                I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                                07-24-2025, 03:02 AM
                              • ShahZaib Ghumman
                                Can I Swap Screens Between Two Hisense 75” QLED TVs?
                                by ShahZaib Ghumman
                                Hey folks,
                                I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                                A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                                So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                                03-25-2025, 10:59 PM
                              • nono34
                                Hisense stuck in Colors cycle like test pattern.
                                by nono34
                                I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                                I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                                10-24-2024, 04:31 PM
                              • frannyjunk
                                Hisense 40H4F no backlight but turns off after splash screen
                                by frannyjunk
                                So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                                TIA.
                                09-24-2025, 10:59 AM
