Another Screen Question
+ More Options
Posts
  • signup
    • May 2013
    • 189
    Hi
    Just a quick question and to get a bit better understanding of when/why screens fail, did read a post that tom replied with how they work which was very educational.
    What I cant get my head round is for example
    you turn the tv on, the screen is shadowing fading in and out, white patches appear etc etc..leave the tv on for 30minutes doing this then all of a sudden you get a cracking 1080p picture that looks perfect.
    Why do they do that? And is this always a fault with the lcd panel (and a tab bodge didnt fix it)
    Thanks in advance
    Re: Another Screen Question
    Heat. Things expand when they get hot. The loose contact somewhere finally makes a good connection.
    • signup
      • May 2013
      • 189
      Fully understand, but!
      When you turn the tv off for 1second, turn it back on and have to go though the same 30minute cycle until the screen is perfect again, it surely cant of cooled that quickly
        The devices are very small (contact area of a few hundreths of a millimeter) so yes, they can cool that quickly.
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • spice_disc
          Vizio TV M50-C1 reboot cycle and static on screen
          by spice_disc
          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
          09-08-2024, 02:37 PM
        • ipatch
          ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
          by ipatch
          i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
          08-24-2024, 02:36 PM
