Magnavox 37MF321D/37 No Power, No LED. Testing a diode.
    Re: Magnavox 37MF321D/37 No Power, No LED. Testing a diode.
    I am having a hard time tracing the copper trace on picture 1134, 1135. Is the resistor connected to C2083 positive leg then it goes some where else?
    • johnboy1313
      • Nov 2012
      • 1959
      Yes, the resistor connects to what would be the + lead of cap 2083 if there was a cap there, and then to inductor 5080.
        OK, now that is better pictures, thanks, and I can now see that the Anode of that 9.1V Zener is connected to pin 1 & 2 which are the +16VDC output pin, the Cathode is hooked up to the resistor, the output side of the resistor is connected to pin 3 which is the +24V pin.
        So the voltage difference between +16V and the +24V is 8V, so at normal operation, that Zener will not conduct until the difference between the +16V and the +24v is higher than 9.1V, this can happen if the +24V is not fully loaded due to backlights inverter circuits is not on yet. When that unloaded +24V goes up higher 25V, the Zener will turn on and clamp down the +24V from going higher than 25V. So if that Zener is shorted or have low resistance the 24V will get pulled down toward +16V and also heat up the resistor.
        So the 9.1V Zener is correct, I would get the 9.1V 1 Watt for the replacement.
        What a differrent when I get to see good clear pictures. Now you understand why we need good clear pictures.
        Bottom line, the power supply will work without the Zener but with less protection if output way over +24V and damage the inverter board..
        • MalodicOne
          macbook pro 820-02100 5v 0 amp
          by MalodicOne
          Unit came to me and customer said they spilled liquid on it. Opened unit and inspected board and saw no signs on liquid reaching the board. Plugged in amp meter and it pulled 20v and booted normally, i connected to internet and ran update on the OS. Came in the next day to test again to make sure unit was functional, now its stuck at 5v and 0 amps no power, no shorts found on so far.
          Tested all CD3217 and RAA489900:
          UF400
          PP3v3_UPC0_LDO- 3.48v, .473 Diode
          PP1v5_UPC0_LDO_CORE- 1.59v, .504 Diode
          USBC0_CC1- 0v, .455 Diode
          USBC0_CC2- 1.66v, .454 Diode...
          07-25-2025, 10:49 AM
        • Scruit
          Diode mode testing of motherboards question
          by Scruit
          (I am self-taught in electronics over 20 years as a hobbyist, but I lack some of the fundamentals that folks who went to school for this would know... so please bear with me as I get deeper into this new hobby of retro computing...)
          I'm familiar with diode mode in that it produces a small voltage between the leads and displays the the amount of voltage drop when the leads are connected... however....
          Why do the board repair folks always put the positive lead to board ground and use the negative lead to probe the board itself? My intuition would be to put the negative...
          04-10-2022, 10:16 AM
        • asr
          Finding replacement diode iPad Pro 3rd gen A1701
          by asr
          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
          07-09-2024, 06:24 PM
        • unimatrix93
          TV backlight zener diode
          by unimatrix93
          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
          The led strips has 9 6V leds.
          02-10-2025, 12:13 PM
        • Askic
          Testing for short circuit in diode mode
          by Askic
          Hello electronics experts,
          On a few occasions I notice experienced technicians inspect for short circuit in diode mode on multimeter. This is OK and in some way equivalent to resistance mode, but more specifically I noticed that they put red probe on ground and black probe (connected to COM input on multimeter) is placed on the rail or pin.
          I wonder why is that. Why not place black probe of multimeter on the ground and red probe on the rail which is tested for short?
          Can you clarify this? When I test if something is short I use diode mode First and then double check...
          02-21-2021, 12:05 PM
