Diode mode testing of motherboards question
  • Scruit
    • Apr 2022
    • 12
    (I am self-taught in electronics over 20 years as a hobbyist, but I lack some of the fundamentals that folks who went to school for this would know... so please bear with me as I get deeper into this new hobby of retro computing...)
    I'm familiar with diode mode in that it produces a small voltage between the leads and displays the the amount of voltage drop when the leads are connected... however....
    Why do the board repair folks always put the positive lead to board ground and use the negative lead to probe the board itself? My intuition would be to put the negative lead to ground.
    Is the voltage being produced at the negative lead, and the positive lead is then measuring voltage that makes it to "ground"?
    If the testing voltage is being created at the positive lead then I would expect diodes to stop any current flowing in the "wrong" direction.
    • 31246
    Re: Diode mode testing of motherboards question
    logic chips have diodes in the input pins connected in reverse to block static electricity - you can check for those going bad.
    i dont see the pint though - most faults are deeper in the chips.
    another reason could be to get a reading faster than in resistance mode.
    • mon2
      • 14656
      Watch this video:
      https://youtu.be/pRpyHF2dfq0
        • Jul 2011
        • 6069
        Originally posted by mon2
        That video was very informative however a little bit long winded but I learn a lot about troubleshoot using that method if you have two identical devices
        Which I never heard of troubleshoot using that method
        Thank for sharing it
        • Baste
          MBR3045CT and SR3045LCT Schottky diode testing help.
          by Baste
          Hello experts,
          Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
          Aneng ST182 Meter.
          Diode mode.
          MBR3045CT:
          Diode mode
          Pin 2-1 - 0.150v
          Pin 2-3 - 0.150v ...
          10-21-2025, 06:14 AM
          FNIRSI HRM-10 Internal Resistance Detector AC Lead Acid Lithium Battery Tester Review on some testing of device
          https://www.ebay.com/itm/405035016711
          I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
          I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it...
          04-13-2025, 08:17 PM
        • quicknick
          Dead Corsair TX650M
          by quicknick
          PSU is made in late 2019 and seems barely used judging by the lack of dust on its innards.
          +5Vsb is all right, grounding PS_on results in a relay clicking and nothing more, all outputs dead without even a flinch.
          Checked inside, at first glance all seemed ok but then noticed something on the primary heatsink, which I promptly removed along with all its attached devices - there were clear signs of insulation breakdown above the C3D04060 diode. The device was overtightened from factory and the tab squished the sil-pad, it all was a matter of time,...
          10-09-2024, 02:52 PM
        • asr
          Finding replacement diode iPad Pro 3rd gen A1701
          by asr
          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
          07-09-2024, 06:24 PM
        • brispuss
          Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
          by brispuss
          Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
          Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
          I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
          12-28-2022, 02:58 AM
