vizio e320-a1 HELP!!!!!!!!!!
  • bmolke
    • Jul 2012
    • 21
    • usa
    I have a vizio model e320-a1. when I plug it in I get white power light on then turns off after 1 second. I can then power on the tv, the power light indicator comes on but no backlights. I cannot turn the tv off after that without unplugging it. All the voltages seem correct from power supply and mainboard. Also have 38 volts going to the led lights(not sure if that sounds correct). The tv simply wont light up and Im not sure what to do. Any help or ideas would be appreciated. thanks
  • mhoward
    • Jun 2013
    • 11
    Re: vizio e320-a1 HELP!!!!!!!!!!
    I have the same problem with my vizio TV if you any body else could help I would be great full
    thanks
    • x_orange90_x
      Vizio E550i-A0 no power, no standby light
      by x_orange90_x
      I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
      11-20-2023, 09:49 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • p-top
      Vizio, E60u-D3, no standby light, no ps_on
      by p-top
      Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
      main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
      PS voltages
      1 VSNS -2mV
      2-5 LED-OUT -2mV
      6-10 GND -2mV
      11 +16VS 16.29V
      12 AC-DET 3.929V
      13PS-ON -3mV
      14 +16VS 16.29V
      15 +16VS 16.29V...
      11-27-2023, 10:44 AM
      Lithonia Lighting versus Light of America Compact Fluorescent product quality
      I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
      I also have back when Light of America had these light bulbs available for yard lights
      The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
      While the Lithonia lighting fixture has all most certain bulb failure
      So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
      I have only had this light fixture for not more than a year if it...
      07-02-2023, 03:45 PM
      LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
      This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
      09-07-2024, 03:40 AM
