Philips 40PFL3505D/F7 Question about FET replacment
    Re: Philips 40PFL3505D/F7 Question about FET replacment
    Measure voltage across C1607.
    • kevinm34232
      • May 2012
      • 1884
      There is 117V DC
        Seems very low. What is your AC line voltage?
        • kevinm34232
          • May 2012
          • 1884
          120VAC. Did you see the last post on page 1, Im getting 345V on center pin of Q1701, but nothing on other legs.
            I suspect IC1702 TEA1611T.
            • kevinm34232
              • May 2012
              • 1884
              Pins 8 SH, 9 GH, and 10 VDD, are those voltages coming OUT? Because I have about 0v on all 3 of those pins. On the other side I DO have the voltages, like VAUX, VDD, RESET, and GL.
              • kevinm34232
                • May 2012
                • 1884
                Hey Tom I ordered the new IC, but out of curiousity based on the pic are pins 8-10 the outputs from the IC? Im just not sure if that is voltage going into or out of the IC.. Thanks!
                  Outputs are pin 9 and pin 12. Pin 8 is midpoint sense (used to drive pin 9 gate FET so it is not damaged.)
                  • kevinm34232
                    • May 2012
                    • 1884
                    OK so Im getting output 6V from GL but nothing from GH, does that tell you anything?
                      And pin 8 you get?
                      • kevinm34232
                        • May 2012
                        • 1884
                        When I checked I was getting little to nothing from pins 8-10. Nothing even close to 170V. I have the working PS board and those voltages were all high, and the ones on the right side were all the same. I just wasnt sure if one of those 170v was supposed to be coming into the IC and maybe that was missing. If that makes any sense...
                        Another words where is this 170+-V coming from?
                          The only way that could happen is the IC switches on the lower FET but then doesn't turn the next stage on (the upper stage.) I think it is faulty because if it were disabled then both channels should be at near zero, it makes no sense to keep the lower FET switched on all the time.
                          • kevinm34232
                            • May 2012
                            • 1884
                            Thats what Im asking so that 174V at the gate of Q1701 should be generated by the IC?
                              Yes. The chip generates about 10V~15V between pin 8 and pin 9. This turns the FET on. Note that when first starting, the mid point voltage on pin 8 will be low (0V). It will slowly ramp up to half the supply voltage, around 160V or so. The voltage on pin 9 will follow it. But it looks here like the chip just has the low output continuously enabled for some reason, I'm not sure why.
                              • kevinm34232
                                • May 2012
                                • 1884
                                Ok thank you will let you know after new chip arrives..
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  Hey Tom received and replaced IC1702 and that fixed backlight and finally fixed this power supply, thanks for the help!
                                  As a side note, these boards are really sensitive and the pads easily will come off the board with any pressure and heat.
                                  • G33RT
                                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                    by G33RT
                                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                    It does power up when pressing the power button.
                                    I already try the power button while plugin the plug with no result.
                                    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                    Could this be an PSU or eMMC issue ?
                                    Today, 03:43 AM
                                  • aidanmo
                                    Philips 43PUS7506/12 - Loud blown out sound
                                    by aidanmo
                                    I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                    I thought maybe the speakers got damaged, so I replaced them - no dice.
                                    • Using the internal speakers, it always happens.
                                    • Using the headphone jack, it never happens.
                                    • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                    02-28-2025, 03:13 PM
                                  • Cornito
                                    Philips 50PUH6400 bad color and gosting / slow motion on one side
                                    by Cornito
                                    Hello Team,
                                    New issue on LCD panel where I need to find out the cause and the potential solution.
                                    This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                    I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                    When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                    I've checked voltages, no issue found comparing right and left side of the panel driver.
                                    VHG VGL CKV... are the sames on...
                                    03-08-2024, 06:41 AM
                                  • Vasmane
                                    Philips 37pfl9632d/10 no image after main board replacment
                                    by Vasmane
                                    Hi guys and thanks for accepting me in your community. Firstly I want to say that I've never done any repairs on TVs , but I have basic electronic knowledge. So the thing is that my tv main board failed and I've found the same board but from a 32” screen. Tv powers up now but I don't have image on screen (backlight is on) . The 32” board connects directly to the tcon board but mine connects to other and then the tcon. I'll post photos later. I'm not sure if this is a firmware problem or hardware. However , I can connect the one cable straight from mb to tcon and get distorted image so I can...
                                    09-25-2020, 02:02 AM
                                  • spantor
                                    Activate power board Philips 40PFH40009/88 tv
                                    by spantor
                                    Hello partners.
                                    Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                                    The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                                    02-11-2024, 05:07 PM
