Philips 40PFL3505D/F7 Question about FET replacment
    Re: Philips 40PFL3505D/F7 Question about FET replacment
    Measure voltage across C1607.
    • kevinm34232
      • May 2012
      • 1884
      There is 117V DC
        Seems very low. What is your AC line voltage?
        • kevinm34232
          • May 2012
          • 1884
          120VAC. Did you see the last post on page 1, Im getting 345V on center pin of Q1701, but nothing on other legs.
            I suspect IC1702 TEA1611T.
            • kevinm34232
              • May 2012
              • 1884
              Pins 8 SH, 9 GH, and 10 VDD, are those voltages coming OUT? Because I have about 0v on all 3 of those pins. On the other side I DO have the voltages, like VAUX, VDD, RESET, and GL.
              • kevinm34232
                • May 2012
                • 1884
                Hey Tom I ordered the new IC, but out of curiousity based on the pic are pins 8-10 the outputs from the IC? Im just not sure if that is voltage going into or out of the IC.. Thanks!
                  Outputs are pin 9 and pin 12. Pin 8 is midpoint sense (used to drive pin 9 gate FET so it is not damaged.)
                  • kevinm34232
                    • May 2012
                    • 1884
                    OK so Im getting output 6V from GL but nothing from GH, does that tell you anything?
                      And pin 8 you get?
                      • kevinm34232
                        • May 2012
                        • 1884
                        When I checked I was getting little to nothing from pins 8-10. Nothing even close to 170V. I have the working PS board and those voltages were all high, and the ones on the right side were all the same. I just wasnt sure if one of those 170v was supposed to be coming into the IC and maybe that was missing. If that makes any sense...
                        Another words where is this 170+-V coming from?
                          The only way that could happen is the IC switches on the lower FET but then doesn't turn the next stage on (the upper stage.) I think it is faulty because if it were disabled then both channels should be at near zero, it makes no sense to keep the lower FET switched on all the time.
                          • kevinm34232
                            • May 2012
                            • 1884
                            Thats what Im asking so that 174V at the gate of Q1701 should be generated by the IC?
                              Yes. The chip generates about 10V~15V between pin 8 and pin 9. This turns the FET on. Note that when first starting, the mid point voltage on pin 8 will be low (0V). It will slowly ramp up to half the supply voltage, around 160V or so. The voltage on pin 9 will follow it. But it looks here like the chip just has the low output continuously enabled for some reason, I'm not sure why.
                              • kevinm34232
                                • May 2012
                                • 1884
                                Ok thank you will let you know after new chip arrives..
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  Hey Tom received and replaced IC1702 and that fixed backlight and finally fixed this power supply, thanks for the help!
                                  As a side note, these boards are really sensitive and the pads easily will come off the board with any pressure and heat.
                                  • osman68i
                                    Philips Coffee Machine PHILIPS EP5441 1.9.30.330.0
                                    by osman68i
                                    I need some advice about mainboard of Philips Coffee Machine PHILIPS EP5441 with 1.9.30.330.0
                                    u2 is shorted. I can only read MX1 . cable goes to display panel....
                                    Today, 01:55 AM
                                  • Sharpa
                                    Repair attempt Philips 55OLED804/12
                                    by Sharpa
                                    I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                    The symptoms when bought: Philips logo appears then tv turns off
                                    Things tried so far:
                                    1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                    2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                    11-22-2025, 08:30 AM
                                  • alro7779
                                    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                    by alro7779
                                    Hello, guys!
                                    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                    09-14-2025, 12:25 AM
                                  • G33RT
                                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                    by G33RT
                                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                    It does power up when pressing the power button.
                                    I already try the power button while plugin the plug with no result.
                                    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                    Could this be an PSU or eMMC issue ?
                                    07-19-2025, 03:43 AM
                                  • double_DD
                                    Philips curling iron - is this a common AC cable?
                                    by double_DD
                                    Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                    As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                    Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                    08-18-2025, 10:04 AM
