LG 42PC3D-UE Plasma no video no screen glow.
    Re: LG 42PC3D-UE Plasma no video no screen glow.
    Adjust all voltages to panel spec, then you need to install maldischarge ROM using LG JIG. There is a reason I do not pick up these TVs.
    • kevinm34232
      • May 2012
      • 1884
      Oh no seriously!?! Vs and Va are good. Is this jig available?
      • kevinm34232
        • May 2012
        • 1884
        So since I don't have the jig is it replacing the control board? I tried turning down Va and Vs slightly with no change.
        • capkid
          • Oct 2010
          • 1339
          Replacing the control board most likely won't help. You need the jig or another programming device to flash the EEPROM. The jig is around $160.
          Is your panel a PDP42X3? 42V7 is the only panel version I couldn't flash successfully. I know others have had issues with 42V7's, also.
          LG Plasma Mal-Discharge Correction Service
          • kevinm34232
            • May 2012
            • 1884
            Panel is PDP42X30401. It's not worth spending on that kind of $ on the jig, Im so happy it's working at this point after getting that IC out of the board.
            • capkid
              • Oct 2010
              • 1339
              42X3's clean up nicely when the control boards are flashed. I've done a few. Enjoy your TV.
              • kevinm34232
                • May 2012
                • 1884
                Where would one get that jig?
                • capkid
                  • Oct 2010
                  • 1339
                  If I remember correctly, I got mine here: http://www.appliancepartspros.com/lg...ap5592589.html
                  You can also get it here:
                  http://www.encompassparts.com/item/8...AD31752601/JIG
                  http://www.mcmelectronics.com/produc...-833%26y%3D-88
                  It looks like the price has increased quite a bit.
                  • Ritalin
                    • Sep 2010
                    • 194
                    #29
                    Man, I have 4 LGs that probably need their IPMs replaced... at least I got them free... But now I don't know if I might need that Jig as well....
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #30
                      http://www.ebay.co.uk/itm/LG-JIG-/26...ccee342bc#shId
                      not sure if they will post outside the uk though good price imo
                        I'm not sure but I think that is a different jig for updating firmware via the VGA port.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #32
                          yes i think your right looking at this other ebay link looks like some other leads etc would be needed to make it work so may not be a good buy after all
                          http://translate.googleusercontent.c..._ndt9VXcB4F8gQ
                            2,399 rubles is only £50 so it might not be too expensive.
                            • capkid
                              • Oct 2010
                              • 1339
                              I'm now offering a service: https://www.badcaps.net/forum/showthread.php?t=29263
                              • iZakre
                                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                by iZakre
                                Hello everybody!
                                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                The thing is that I had installed TeamViewer and could log into the computer...
                                02-19-2023, 02:27 PM
                              • Ryan.man
                                by Ryan.man
                                02-04-2025, 12:23 PM
                              • ferah831208
                                HP gaming 15-0013dx quanta G3HA no video, screen polarize on and off loop
                                by ferah831208
                                I have an HP gaming 15-0013dx laptop , motherboard quanta G3HA with AMD Ryzen 5 cpu and Nvidia discrete grsphics card. The laptop turns on and u can see the screen polarizing on and off in a loop but no video signal. All voltages are ok measured and stable (I checked all with oscilloscope). This schematics don't have power sequence but I'm using a similar sequence from another laptop with AMD CPU and I get all to the point CPU must release apu_pwrok and apu_rst#, this signal comes valid only for the period of time the screen is polarized and they disappear and same loop behaviour (active/inactive)....
                                12-07-2024, 04:02 PM
                              • Alicat
                                Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                by Alicat
                                Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                Model number is TH-50PZ85U
                                Power comes on and the red power light stays on solid.
                                Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                I also hear a few clicks.
                                I also think my parents said there was a thunderstorm and the TV failed after that.
                                Section 6 in the service manual talks about power and no screen,...
                                10-30-2024, 10:09 AM
                              • reformatt
                                by reformatt
                                07-31-2025, 08:37 PM
