Sony Bravia 40" LCD TV KLV-40S400A - Works fine at first then lines after warm up
  • funtastic
    • Nov 2012
    • 63
    • New Zealand
    I'm looking at buying the above lcd tv from an auction site and it states that after it warms up it has intermittent lines down part of the screen and just wondering if it's worth buying for 50 NZD.
    Would it be the t-con, panel or something else? I won't bother if it's a bad panel.
    Re: Sony Bravia 40" LCD TV KLV-40S400A - Works fine at first then lines after warm up
    It's probably a LCD tab bond issue.
    • thstuff
      SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
      by thstuff
      This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
      Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
      1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
      2) Waited 30 seconds, then pressed remote Power button and "Select language"...
      01-30-2023, 05:01 PM
    • JUCaESAl
      Sony bravia KD-65AF9
      by JUCaESAl
      Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
      Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
      10-20-2025, 04:03 AM
    • visionbluedemon
      Help. Sony kd-65x85dj vertical lines
      by visionbluedemon
      First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
      Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
      tried blocking LC lines too, but same results
      is it lcd panel issue or tcon board issue?...
      07-25-2025, 04:56 AM
    • ggil44
      Sony XBR-65X750D Horizontal lines bottom of screen
      by ggil44
      Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
      05-30-2023, 07:51 PM
    • PopsCaps
      Sony Bravia KDL-40V2500 that will not power on
      by PopsCaps
      I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
      I do not hear any sound and I cannot see any backlight.
      I have tried disconnecting every cable on each board one at a time to see if anything changes.
      The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
      My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
      03-25-2025, 11:23 AM
