Vizio LCD E420VO 2 seconds to black
  • Cosmo66
    • Nov 2012
    • 87
    I have 5 volts standby present. When I press power button, PS_ON goes to 2.98 volts, backlights come on, screen displays Vizio logo for about 2 seconds, then the power supply shuts off and the TV goes back into standby.
    It appears that this power supply is a power supply/inverter board in one, and the main board is a main/tcon in one board.
    I see no bad caps or signs of anything bad on either board. I am suspicious of the main/tcon board. How can I verify the power supply is good? What other signal is it getting from the main that might make it shut off?
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Re: Vizio LCD E420VO 2 seconds to black
    The inverter board may be shutting down because of a shorted transformer or IC on the inverter board... do you still hear audio when the video shuts down?
    • Cosmo66
      • Nov 2012
      • 87
      no audio. I tried to plug in a dvd player to check this. The TV turns on, displays the Vizio splash screen, and then shuts off before I can get to any menus or change inputs.
      This is why I'm a bit suspicious of the main board. I'm thinking possibly corrupt eeprom or something like that maybe shutting down the power supply after the splash screen.
      If I hold 3 volts on the PS_ON, shouldn't the power supply stay on if it's good?
      • Cosmo66
        • Nov 2012
        • 87
        *bump*
        I want to power up the power supply without the main attached. What would be the best way to do this?
        • HiLite
          • Sep 2013
          • 3
          • US
          Was this problem ever resolved? If so what was the resolution?
            Yes, you can force on the power supply by using 1 K resistor between the PS_ON pin and the 5VSTBY pin, BUT you have to make sure to disconnect the cable on the PS_ON pin that goes back to the main board because the main board will try to keep that line low.
            • HiLite
              • Sep 2013
              • 3
              • US
              I went ahead and replaced the power board and problem remains. That leaves the main board, but I can't find it anywhere everyone is out of stock.
              EV420VO
              3642-0972-0150(4E)
              CSD: 3642-097209395
              • HiLite
                • Sep 2013
                • 3
                • US
                I now have replaced the main power and previously replaced the power board but problem remains. Vizio logo on frame has a Amber light, turn on the tv the Amber light turns white and Vizio appears on the screen, 2 seconds later the tv turns off and the light on the frame goes Amber again as if in standby.
                HELP!
                  But did you try forcing on the power supply board to find out if power board is OK as suggested in post 6?
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • ygorsan
                    by ygorsan
                    🧩 Problem Summary:
                    • I
                    07-28-2025, 08:34 AM
                  • jb_Bak
                    by jb_Bak
                    CN6401
                    Pin 01 NC
                    Pin 02 NC
                    Pin 03 "BL_ON": 0V
                    Pin 04 "N/C"
                    Pin 05 "STBY 3.3V": 3.5V
                    Pin 06 "GND": N/C
                    Pin 07 "AC_OFF"...
                    09-27-2021, 04:52 PM
                  • JDC
                    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                    by JDC
                    ONN 100012588
                    Issue: No Power, Then Rebooting After Main Board Change
                    Short answer: replace main board and power board
                    Technical answer: replace main board and Q306 & Q307 on power board.
                    Long answer:
                    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                    07-15-2022, 07:39 AM
