Hi all it looks like it time for a new lamp again,picture getting dark.I have had this set from new, just over six years and in that time i have changed the lamp twice,at just under £100 a go.I have looked on line and to buy one in the UK the cheapest i can find with the holder is £97 free post,but from the USA £23 plus £29 post,there is also one from Germany for £43 free post but looks like it will take a time to get here.What one should i go for,can any American forum users tell me if the ones on ebay over there are any good or to be avoided Thanks Flocko
JVC HD-70ZR7J Lamp replacement
Re: JVC HD-70ZR7J Lamp replacement
Thanks for the reply,the projector lamp for my set over here in the UK is £97 rip off, the same lamp from the US is $34.54 (£23) plus post it is still half the price of the UK one, but are they any good or not,i dont want to buy one for it to only last six months.Comment
by titomno2Hi guys,
I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
Then the screen won't work for a long period of time.
If I wait 1 or 2 hours it work again most of the time.
When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated... -
Assuming...7 Photos -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by flat-eartherI have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
I have opened the camera and I think there is enough room to add something inside to accomplish this:
The camera is powered by a 3.7V nominal single cell lithium ion battery.
So I need to connect another battery in... -
by the_remHello guys,
I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow... - Loading...
